Shop size?
~400Sq feet
Insulated?
Nope, not a drop.
Climate?
Northern Connecticut, so southern new England. 85* summers and 10* winters (except for this year...)
Heat source?
I have been using a 5200 BTU infrared heater (
http://www.tractorsupply.com/tsc/produc ... _vc=-10005). It takes about an hour to raise the temp in the garage ~15-20* over outdoor temp. When its 30* out, working in 45* is still not exactly pleasant, but it definitely helps to stand in front of it.
Trials and tribulations you've experienced?
Even though 5200 btu's should be sufficient, I think its the lack of insulation and early sunset that really mess with the whole keeping warm aspect. I searched for other solutions, but couldn't find a pellet stove cheap enough.. and wood isn't ideal for the fact that my time is often unexpectedly cut short (nap times over!).
I came across a fellow who I'll be doing a barter deal with for a NG/LPG stove that I intend to hook up with a 100lb propane cylinder in the garage. It has an electric circulation fan, and is allegedly good enough to heat a 1200 sqft house.. so running it on a mild temp setting should prove to be cost efficient and worthwhile. Even more so when I get a chance to get some insulation up.
Still have some things to work out of course. I am pretty positive it needs to be elevated. 18" from the air inlet to the floor is the minimum. So I'll either be fabricating a stand or stacking some cinder blocks.
quick question - for those of you who use a propane heat source in your garage.. Do you keep the cylinder inside or outside?
Tucker
Driven5 wrote:
