Interesting take on electric reverse found on LocostU.K. http://www.locostusa.com/forums/viewtopic.php?f=10&t=13066 |
Page 1 of 1 |
Author: | Firehawkslplus [ November 24, 2011, 12:46 pm ] |
Post subject: | Interesting take on electric reverse found on LocostU.K. |
The company makes this for both chain drive & shaft drive. The down side is it only works W/IRS i.e. fixed center section. http://www.lynxae.co.uk/Products-Bikesports.htm RCD |
Author: | JagLite [ September 17, 2014, 4:40 pm ] |
Post subject: | Re: Interesting take on electric reverse found on LocostU.K. |
Excellent find! |
Author: | ccrunner [ September 18, 2014, 3:18 pm ] |
This is in fact a great find- thanks for sharing For a car heavier than 900lbs with a driveline setup, it works out to about 635.00 (USD) before shipping- not bad at all... Again- thanks for the link. -ccrunner |
Author: | rapt [ September 18, 2014, 7:30 pm ] |
Did they give weights in the specs? I saw none so far in the stuff I've seen. |
Author: | ccrunner [ September 19, 2014, 10:54 am ] |
rapt wrote: Did they give weights in the specs? I saw none so far in the stuff I've seen. They do.. on the link in the first post, look under the pic of the starter, or in the description next to the price... their breakout is cars under 450kg (992lbs), or under 800kg (1763lbs)-- should cover most of us BECs here... Also of note is the toothed plate (tiny flexplate if you will) measures just 5.5" to 6.2" (you choose your size).. -ccrunner |
