It is currently May 15, 2024, 9:41 pm
PostPosted: April 11, 2012, 6:02 pm
I need to relocate the bike's OEM oil cooler, and I am a bit worried about the lines... I'd like to just cut them off (they're currently much too long), and use some high pressure rubber hose to re-route/reconnect the cooler to the bike's oem oilpan fittings. I'm a bit concerned about the hoses I put 'inline' staying put, as the tubing I cut will have no barbs on it where I slip the new rubber hose over it.. any thoughts on making this lo-buck approach work? I guess I could have new hoses made, but this is cheap/easy/do it yourself...
thanks-
ccrunner
Dean
1963 Volvo P1800 Restomod
viewtopic.php?f=36&t=19397
PostPosted: April 12, 2012, 7:39 am
I'd have to see the tank, but for the most part, it is a bad idea due to the pressure and temp change involved. A hose can creep right off the cut line. A little oil inbetween and it is off.
You can try brazing/silver soldering a barbed fitting or original end back on, a few turns of thin solid wire soldered around the cut end, or flaring the cut end to form the flare. The flaring tool is specialized and expensive as the inner mandrel must be tiny, but an aircraft repair facility or aircraft mechanic school should have a mechanic/teacher who will do it for you for a couple bucks. The mc line maybe a little harder than aircraft line, but that just means it takes a few more passes, not greater pressure on the tool.
PostPosted: April 12, 2012, 12:02 pm
Not sure as to the engine you are using but in some cases you can get adapters to connect AN fittings which are much easier. Example with the Hayabusa I got fittings that go directly to the engine and convert to AN
Then I ran that through a thermostat controller
Then piped that to the cooler.
On suggestion is to not run the lines till you are 100% on everything, bodywork etc. I had to redo mine 3 times.
Ali ---
-- Push the pedal on the right, the one in the middle is for wussies ---
- Link to build blog- http://BluLi7ard.blogspot.com/
PostPosted: April 12, 2012, 12:44 pm
I like the look/functionality of your setup Nufun.. I'm uncertain of the availability of those aftermarket oilpan fittings for my less-popular VRF800 engine.. I hear what you're saying about placement.. I have a crossmember very close to one of my fittings- I know the oem end will go on, but those that you're running just wouldn't fit with my current setup.. My car is tiny (Honda N600), and I'm finding I'm often measuring clearances in milimeters- so little room for stuff!
-I think I see where you're going MiataV8... I wonder if I could cut my lines, and just tack two or three small weld beads around the circumference of the end of the tube to act as a 'flair' to keep the hose from backing off :?:
ccrunner
Dean
PostPosted: April 12, 2012, 1:17 pm
I think the fittings exist somewhere, check these guys out http://www.aaperf.com/vfrkit-gen5.html
Ali ---
