horizenjob wrote:
when i spon the car at LRP the assend jumped in the air 3 time .
Well that sounds like it would do it, quite a ride! I can see that causing some damage...
you have run at LRP i don't know how fast we are going but it's quick .
i'm getting very tired of this car ! 2 plus years of R and D just when i think it's all good to go the POS brakes again . 1st it's eating clutches so i design my own cable ,peddle and clutch cam and get rid of the master and slave set up the motor comes with . then the barings in the out put shaft ( counter shaft ) extension start to get crap out every event . redesign that . then it starts eating chains 14 of them so i drop the motor in the chassis and move it all the way over to the right side to fix that . and that was after trying drive shafts and all other types of crap . then it lead into it eating the rollers on the chain tensioners . so i went to a gear that just lead into eating the chain again . so i tried a aluminum gear then a delrin gear then to a roller that is used on dirt bikes . then made my own roller out of 3" round stock of delrin . that worked i am now getting many events out of the chain and roller set up . did i leave out that i had to design a new chain tensioner too after moving the motor the last time the stock tensioner would no longer tension the chain at full compression of the suspension .
if any one wants to turn a bike motor sideways in a chassis on mid engine rear drive car for get it ! it's a dumb idea there is just no plus to do it .
i took today off from work to start the new back half on my chassis so the motor sits in it the way it should .
