Looking for a solution to another of our unique BEC issues..
I'm running a stock VFR800 engine (about 105hp/ 55ft lbs) in my tiny BEC project.. haven't weighed it yet, but likely around 1300#..
My issue is that once I'm up in 4th or 5th gear, taching around 7,000/8000rpm, if I really step on it, the clutch will briefly slip until I get out of the throttle..
Now, I know I'm asking a lot more of this clutch than it was designed for, so I'm just trying to make what I have work... I installed Barnett springs, and that seems to have 'almost' taken care of the issue (it holds better now, but still not quite there).. When I went in to swap springs, I pulled the clutch pack apart and found several steel discs were heat discolored- a few of them showed signs of some serious heat; heat that I believe I put there with my "let's find the weak link and make this thing slip" excercise .. (the friction discs all looked really good- this motor has about 17K on it)
So, with my limited knowledge of MC clutches, I think I've done a few things wrong... I put the clutch back in as I found it (shame on me, I have another engine sitting in the corner that very likely has 100% perfect steel discs in it)... ALSO, I'm running Valvoline car engine oil (10-40) in the bike motor (which worked fine when the engine was in the bike), and I'm thinking I need to run 'real' motorcycle oil in consideration of a slipping clutch..
The reason for this post is to get thoughts on the next step... once I replace the oil and put in 'good' steel discs, if is still slips, it seems the next thing is an aftermarket clutch (or friction discs at least).. I've been reading up in the MC forums, and lots of guys try the Barnett clutch, hate it, and end up pulling it out... Having said that, they're not trying to propel a 1300 lb car down the road on a tiny clutch either..
Just wanted to get your thoughts/experience on this..
thanks-
ccrunner
Dean
1963 Volvo P1800 Restomod
http://locostusa.com/forums/viewtopic.php?f=36&t=163091959 Berkeley SE492 Restomod...
viewtopic.php?f=36&t=19397"ccrunner's 1960 MGA coupe Restomod" found on MGExp.com
