It is currently April 17, 2024, 8:46 pm
PostPosted: May 29, 2014, 6:41 pm
I'm gathering parts for a GTS based locost7 build and have been hanging around this forum for a few years. Its made me realize that there are a lot of knowledgeable people that frequent many different forums but post regularly here.
So I thought I would throw my questions out here, in case anyone else is watching the Morgan.
So here goes, I know that they are using a harley based motor and a miata transmission with a shaft drive rear axle.
My questions are- how are they doing the clutch?
is the miata trans that small that they can move it back into the passenger compartment?
has anyone seen a harley motor attached to a moto guzzi transmission?
Anyone have any other thoughts on the Morgan 3 wheeler
Doug
PostPosted: May 29, 2014, 8:40 pm
Because the bottom end of the Harley is inherently weak (very short girdle) they use a jackshaft to keep many of the forces isolated from the Harley. This makes it a long package which actually works out to get the shifter back where humans can reach it
Google Miatabusa and they have a great write up on what it took to hook a motorcycle engine up to a car transmission. It's basically the same thing Morgan did.
PostPosted: May 30, 2014, 9:25 am
Hey Carguy- congrats on your purchase of the ultralight. That really seems to me to be the ultimate 7.
And thank s for the reference above. I spent way more time then I have following the google threads LOL
PostPosted: May 31, 2014, 8:22 am
Great info here:
http://www.blackjackzero.com/pages/gallery.html
PostPosted: June 2, 2014, 12:09 pm
Doug
well actually, it not a Harley-Davidson engine, its an S&S X-wedge, which a proprietary S&S engine newly designed from the cases up that shares nothing with their other HD Evo-clone engines, except the general architecture of being an air-cooled, pushrod OHV V-twin.
PostPosted: June 2, 2014, 12:27 pm
Actually not so much. if you go here, and read the design specs...
http://www.morgan3wheeler.co.uk/desktopindex.html
you'll find that the S&S engine is mated to the miata box with a proprietary bellhousing, and that teh power is transfered to a bevel-gearbox which has its output sprocket in line with the swingarm pivot, power is transferred to the rear wheel with a toothed belt.
here's a picture of the engine, cush drive, clutch housing and gearbox all bolted up
chjeck out the pictures in this discussion thread from the Morgan enthusiast/owners group...
http://www.talkmorgan.com/ubbthreads.php/topics/75889/New_M3W_photos
PostPosted: June 2, 2014, 3:23 pm
Yes, see the long section between the engine and the transmission, that not there just to make it the proper length. I've followed numerous builds doing this because i have a spare S&S engine. Unless they added the jackshaft to isolate the engine from the forces, the bottom end didn't last because of the short girdle. A 4 cylinder doesn't have this issue.
I've decided that a belt or chain drive to an automatic transmission would do the same job without adding the length. The torque converter would take up much of the abrupt application of power and the give in the belt or chain would help with the rest.
It's just that this issue has been worked on so long that most people skip over it because they know they are going to have to add the jackshaft for placement not realizing that it has another, even more important purpose.
PostPosted: June 2, 2014, 11:26 pm
Yeah there's a cush drive in that housing, though i couldnt find any schematics for whats inside. An article i found on the london telegraph website mentioned that it used rubber cushions like those used in motorcycle rear wheels, but thts about all i could find.
PostPosted: August 24, 2014, 12:10 am
I'm new here, but have followed the M3W quite closely and I'm a member of the Talk Morgan forum in the UK, although I live in the great St. Louis MO area.
The S&S motor uses NO jack shafts. The Harley or S&S both have a short splined shaft on the primary side of the motor and the Morgan uses a modified Harley compensator. The cut off the sprocket teeth and they "stack" the compensator with a housing extending back toward the transmission. Within this housing is the comp that smooths out the torque pulses from the V-twin motor.
The flywheel is supported by a sandwiched plate with a short shaft that mimics the end of the crankshaft. This short shaft runs through a wide double roller sealed bearing in the adaptor plate. The comp housing then has a rubber "cush" joint similar, if not the same, as what BMW uses on the rear of their driveshafts in their cars. This bolts in between the comp housing and the short stub shaft for the flywheel. On the flywheel side, the parts are as they are in a Miata.
There is a short driveshaft that the slides into the trans and then bolts to the front of the bevel box made by Quaife special for Morgan. I believe it to be around a 2:1 ratio with the remainder made up on the rear belt drive.
If anyone here is familiar with the larger CVO late model Harleys with the 110" motors, you will know that the compensators on them are just plain junk. My '09 CVO Road Glide has low miles and I've not thrashed it badly and I've still got a good comp. But I know guys on their second or third comp.
Morgan has now gone away from the Harley style comp and are using a true cush drive made for their application from Centa in Europe. This is has a shaft with four round slots about 4" in diameter and a housing slightly larger with four round slots in it. In the four slots they have four rubber round logs that act as a cushion for the torque and there is no metal to metal like on the Harley comp.
I've started to pick up parts for one as a project build for myself. I have a couple hundred mile 1800GL Goldwing final drive box that's 2.75:1 and I plan to do a front bearing support for the driveshaft and then where the wheel bolts on with be my belt drive sprocket. I also have a very low mileage Touring rear wheel in a 16"x5" with the HD rotor and disc caliper. I'll make up my own swingarm etc.
But my main concern has been the V-twin, although that's what drew my interest in the first place. These are ALL listed as motorcycles regardless of steering wheel and seat/shoulder belts.
The original cycle car was made by Liberty Ace in Washington state. They made them using the "B" Harley motor with the counterbalanced motors. This way there were a LOT smoother than the non balanced rubber mounted touring motors. The Liberty used a Miata 5 speed just as Morgan does now. The Liberty used a Goldwing complete swingarm and the driveshaft was offset toward the rear of the interior to match up with the offset side drive on the Goldwing driveshaft in the swingarm assembly.
I joined here to as questions about running a Miata as a standalone motor/trans in my project car. I'm really thinking that just going with the complete 1.6L or 1.8L motor/trans combo will be better, no torque or comp issues to deal with and a complete 40k to 55k motor/trans can be pickup with free shipping for $1100 to $1400.
Although I DO want to run a distributor and carb setup. I understand the Ford Escort used the same motor and the distributor from it will replace the crank position sensor that slides into the rear of either the left or right cam, depending on 1.6L or 1.8L.
Enough on that for now.
If you go to my Picture Trail album link, you can see some pictures that I've stored there under the Morgan Three Wheeler album. You can also see some of my project and builds there. I'm particularly proud of my '40 Willys coupe with a blown 392 Chrysler hemi. I put 16k miles on that car in '00 and '01 and 6200 miles were all done in 23 days when I was part of the Rod & Custom Magazine's first Ego Rama Shootout. My wife and I left Michigan and drove to Bonneville and met up with everyone there. We then drove 1700 miles up through Salt Lake City, Jackson Hole, Yellowstone, Idaho, Lake Tahoe, on to Pleasanton CA for the Good Guys West Coast Nationals in '01. That was a real trip with lots of fun along the way.
http://www.picturetrail.com/Dan_Lockwood
Sorry to ramble guys, have a great weekend.
Dan
1976 FLH Electra Glide
2009 FLTRSE3 Road Glide
Boardtrack Racer Project Bike
Morgan Three Wheeler Project
Picture Trail Photo Albums
PostPosted: August 25, 2014, 4:01 pm
Small world- I saw your car on the tour and had a short chat with you. I may even still have some pictures.
I'm still following the 3W Morgan and bought a 673 Silverwing to use as a donor. Turns out that I really enjoy riding this bike and can't bring myself to parting it. We'll see what winter brings.
PostPosted: August 26, 2014, 9:37 pm
Dan, thanks for the info on the Moggie cush drive.
kewl Willys ;-)
My moggie-style three wheeler has a Suzuki VS1400 swingarm, final drive and rear wheel with the stock intruder cush drive in the hub.
PostPosted: August 27, 2014, 12:11 am
Yes, thank you...Learning more about the cush drive required for a 2L V-twin is very relevant to some of my less conventional thoughts. :cheers:
PostPosted: August 28, 2014, 9:06 pm
That is very cool that we talked. Can you refresh my memory a bit? Pictures would help tell the place that we chatted.
My wife still almost cries when I mention the Willys. She literally dislikes me very much for that sale. But at the time moving on to the '55 Nomad gasser project with a Beck Racing Engines 540 bbc, 4L80E reworked, all new suspension with straight axle up front, it would have been great. BUT... I moved to MO in '02 and worked long hours and traveled a lot for work, in fact I've been in Evansville since Tuesday. I understand I just missed the oldest car show in the US, the Frog Follies. At least that's what one of the guys I was working with told.
I'm actually on LocostUSA for information about running a Miata as a standalone in a potential reverse trike like the older 2 and 4 seater Morgan three wheelers. I still think the V-Twin, specifically a Harley 110" "B" motor with the counter balance shafts would make a great donor, but the whole compensator issue has me a bit gun shy. If I were to just use the complete motor/trans instead of just the Miata 5spd, that would simplify things a LOT... I already have the bevel box as mentioned before and I feel that with the Goldwing 1800 not being able to destroy it, it should hold up to at least the Miata 1.6L or 1.8L power. The Miata 4cyl would be a LOT smoother power than the V-Twin, but the V-Twin has that mystery about it and just plain looks way cool out front.
Thanks to all for the comments.
If anyone has any experience in exactly what distributor from the Ford Escort and some other motors, will work in the rear cam in place of the crank sensor assembly, let me know. I'm also looking at a Holley/Weber 1600 progressive two barrel like what came on the Chevy Chevettes would work on my 1.6L Miata.
Or is anyone familiar with the Megasquirt systems I've read about for spark and fuel injection control for the Miata?
Dan
Users browsing this forum: Google [Bot] and 11 guests
