It is currently May 26, 2020, 12:14 pm
 Post subject: engine mounting
PostPosted: February 23, 2020, 6:59 pm
For those of you using a late model (motor hung from upper frame spars) motorcycle engine in their build, how are you bolting the motor to your frame?
 Post subject: Re: engine mounting
PostPosted: February 23, 2020, 7:13 pm
My 2004 Yamaha R1 motor has the mounting points shown below, as well as two more tapped holes on the other side. Those were not really usable in my application, so I just used the side mounting points. Here's the best picture I could find. It's a bit tough to see, but on the right hand side I have some steel round stock welded to the HSS stubs and a hole drilled to let the threaded rod through. Then on the left side, I put round stock in and tapped it with I think a 3/4" thread. Then a threaded insert goes in and passes the threaded rod through that. Once in place, the threaded insert is tightened against the engine to eliminate any fore-aft movement. Basically just replicated the same system as was on the original bike.
PostPosted: February 23, 2020, 7:28 pm
Nice pic,
Thanks
