It is currently May 15, 2024, 11:43 pm
 Post subject: Removing pinion gear?
PostPosted: December 30, 2021, 1:40 pm
So conceptualizing a mid-engined build here. I'd like to use a direct mechanical connection so as to eliminate the hassles of using a chain. I've got limited fore/aft space, so I'm considering rotating the motor to transverse configuration. My questions are:
-What is the HP gain by removing the extra bevel gear?
-Is it particularly difficult to remove said gear and add a coupling?
-Would there be a significant weight shift towards the drivers side which would unbalance the car?
All feedback appreciated.
PostPosted: December 30, 2021, 3:39 pm
I'm a little confused by your terms.
There are two axles with a differential in the middle.
The diff can be driven by a sprocket via chain (transverse) or a ring gear via pinion (direct couple).
Consider a cush drive in between.
In general, parasitic loss is typically 15% for higher output machines and half that for transverse typical fwd machines without a bevel drive. Many factors go into the total loss.
Imho, the most compact overall in a side by side, rwd config build would be similar to ccrunners Berkley with the bike motor up front between the suspension bits and a long shaft. Make it a little wider so the diff and output can be centered and run parallel to the chassis in a tunnel between the seats.
A chain bec bolted to a bellhousing adapter with a custom adapter on the bec output shaft to support the input shaft pilot on a fwd transverse trans mounted in the rear would have a little bit longer wheelbase but would have roughly half the parasitic loss. The long axle on the fwd trans could be shortened for a narrower track and keep the struts but adapt for smaller od springs.
PostPosted: December 30, 2021, 4:04 pm
OK, I see the confusion. My bad. almost all motorcycle engine's native configuration is transverse. So bike engines either have a sprocket or a bevel gear with shaft drive. What I'm proposing is taking a bike that came from the factory with shaft drive and either hooking straight from the shaft drive output to the diff (with a guibo) or removing the bevel gear and rotating the motor 90 degrees and then connecting to the diff via guibo.
PostPosted: December 30, 2021, 4:30 pm
Better to start with a sprocket bec if going to a sprocket diff than using a shaft drive turned sideways which would require adaptation and will probably have chain clearance issues.
There are examples of both here. Check out John's build with a diy cush driving a diff. A standard guibo doesn't work since the driven sprocket must turn true all the time.
viewtopic.php?f=10&t=19392
