Paigeo's GSXR1000 curved-tube BEC http://www.locostusa.com/forums/viewtopic.php?f=10&t=9392 |
Page 2 of 4 |
Author: | paigeo [ August 8, 2010, 3:42 am ] |
Post subject: | Re: Paigeo's GSXR1000 curved-tube BEC |
I have finished the front suspensions bell cranks. I have used oil impregnated nylon for the bushes. The brakets are made out of 3mm mild steel plate punched out and welded to the centre mount. |
Author: | Miatav8,MstrASE,A&P,F [ August 8, 2010, 7:33 am ] |
Nice fabrication skills. I understand the need for the notch, but it greatly weakened the arm. The depth of the notch should be added with a gusset above the arm across the top. Down the road, if you find the wear rate to be high in this application for nylon, uhmw is a good, long wearing replacment. Don't forget to triangulate the load path through the floor. |
Author: | paigeo [ October 22, 2010, 3:21 am ] |
The latest progress for my build. The suspension is all done. I have used 05 GSXR 750 shocks. |
Author: | motive [ October 22, 2010, 10:52 pm ] |
In a John Wayne accent: "Thats a nice looking wagon...er, car you have there, partner." Maybe Jack can use those wheels on his x-prize car. |
Author: | paigeo [ October 23, 2010, 4:07 am ] |
Oh the "Wagon wheels". They are a little narrow but they are cheap and are sure to produce plenty of Smoke. |
Author: | paigeo [ January 7, 2011, 10:05 pm ] |
Here are the latest progress photos. The chassis has been sand blasted due to surface rust and under coated. The body panels are just temporary to give me an idea of what it will look when completed. |
Author: | Yahshuatwo [ January 8, 2011, 1:30 am ] |
looking very sweet!! keep it up.. |
Author: | Hank [ January 22, 2011, 1:04 am ] |
I wish you luck on completing your build. Between the wagon wheels and the dog feet sticking out the bottom (ala Flintstones power) I lost it. |
Author: | McCheese [ January 22, 2011, 1:07 am ] |
Watch your head on those roll hoops |
Author: | paigeo [ September 26, 2011, 2:50 am ] |
Time for an update. Finally the motor is in. Its a kawasaki ZX10r 05 motor. The diff is mounted on dummy cw mounts at the moment. I will have these cut out of ali once im happy with there design. |
Author: | Yahshuatwo [ September 26, 2011, 12:56 pm ] |
Very nice build! One thought however, have you considered changing the headlights? Some yamaha r1 lights would take it to another level. More sleek and stealthy look/vibe |
Author: | kikiturbo [ September 28, 2011, 5:02 am ] |
with such a diff setup you will have a large bending force on that upper tube that holds the diff... you need to brace the diff against the engine.. |
Author: | a.moore [ September 28, 2011, 10:35 am ] |
Nice work Paigeo. The car is shaping up nicely. Along the lines of Kiki's suggestion - since the bearings supporting the diff are closer to the bottom, that set of mounts will carry the greatest load (well actually the one closest to the sprocket will carry the greatest and the other one will probably be ~1/4 that just eyeballing your differential dimensions) so it would probably be easier to make those fixed and to make the upper ones adjustable. If you place the slotted mounts on the top, you can run a set of turnbuckles forward to the engine and they will always end up in compression (no need to worry about impact loads fatiguing the rod-ends and causing them to fail). If you are not done yet, I would consider reinforcing those lower mounts to at least double shear 0.090" mild steel. Impact loads on solid mounted drive train parts are huge. A picture is worth a thousand words - My Alma Mater did a nice job of eliminating some unneeded metal and simplifying the differential mounting on the 2011 car. Having a tube to support the upper mounts isn't really necessary of you direct the loads correctly. Attachment: IMG-20110505-00078 sized.jpg This is what you want to try avoid doing. The ends of the links are over contained so any flex places the links in bending. Plus the small (1/4" diameter I believe) unrated threaded rod is always in tension. Yea...it failed. Attachment: DSC04394 sized.JPG I would also try to avoid making any of the differential mounts cantilevered off of the tube if possible. Keeping the loads being fed into the tube in tension/compression will probably keep your life the easiest. |
Author: | paigeo [ January 16, 2012, 5:11 am ] |
Painting all done. Now for the final assembly. |
Author: | Laminar [ January 17, 2012, 9:42 pm ] |
I love how you kept the motorcycle handlebar controls behind the steering wheel. |
Page 2 of 4 | All times are UTC - 5 hours [ DST ] |
