It is currently June 6, 2020, 7:49 am
PostPosted: March 10, 2013, 9:43 am
I thought I'd share a couple of quick pictures of the semi-mobile table I set up a couple weekends ago. I got tired of dragging each tool to an outlet in the garage and working on the floor because all of my work surfaces were full of tools/messes.
The belt sander/grinding wheel and the drill press are from Northern, the polishing wheel and bandsaw are from HF. The bandsaw has been outfitted with a Milwaukee metal-cutting blade and slices through thick metal and steel like butter. The drill press is decent, though the cheapo vice I bought for it is trash. The grinding wheel gets the job done and the polishing wheel is 1000x better than the drill-mounted buffing wheels I'd tried to use before.
The only thing left to do is wire up a 4-outlet box to the table so that I can have all four devices plugged in at once. I'd also like to do some kind of drill bit storage to keep everything better organized.
Ford 5.0 into an M3
mikaelvroom.com
PostPosted: March 10, 2013, 11:16 am
Sounds good but I can't see the pictures... Could you try uploading them onto our site? I think our upload problems are fixed for reasonable size jpegs...
PostPosted: March 10, 2013, 11:41 am
Originally hosted them via Dropbox, I just rehosted with Imgur. Hopefully that works for you.
Ford 5.0 into an M3
mikaelvroom.com
