It is currently April 16, 2024, 1:58 am
PostPosted: January 22, 2015, 9:47 pm
So which MIG welder is a good place to start? Have stick and TIG 250amps.
Going to do some thin stuff. 22ga to 16ga. :oops:
Thanks,Randy
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: January 22, 2015, 10:45 pm
Budget? 120V, 220V?
Cant go wrong with Miller or Lincoln if you can afford it.
I have a little 120V Northern Tool welder and I love it. Only thing I don'qt like about it is the heat settings. 1-4 is all you get, Id like to have more control of my heat selection. I paid a little over $400 for mine. Its a MIG and a flux, I always use gas when I weld, just works out better that way, and its a cleaner weld.
PostPosted: January 22, 2015, 11:39 pm
Briggs, under a K+-.
220V also have 3 Phase.
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: January 23, 2015, 1:38 am
Not an expert, but I'm pretty happy with my millermatic 175. The control on thin stuff is very good. I've welded up holes on very thin sheet with no warping or blowouts. I've run 2 large spools of wire through it with no issues. I also like that it's small so takes up less room and is somewhat portable. I'm not a fan-boy, but I've tried several welders and the millers always seem easiest to work with.
Cheers.
PostPosted: January 23, 2015, 10:51 am
I don't know my Lincoln equivalents as well, but it's hard to go wrong with the Millermatic 211. Think of it as a MM180 with dual (120/240) voltage inputs and more power. Although the smaller form factor and ~50% weight reduction in the newer MM190 should be a pretty fantastic option too, if never expecting to need or want the additional plug/output.
PostPosted: January 23, 2015, 9:50 pm
Found a Miller 221,used 25 min's. Guy got sick, for $950.00 . What do you think ?
Randy
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: January 23, 2015, 10:29 pm
Randy
$1400 MSRP. Sounds like a good deal to me. Make sure you weld a bead with it before you buy if it comes with a bottle and some extras, I'd go for it.
PostPosted: April 6, 2015, 4:48 pm
I love my Lincoln 110V
PostPosted: April 29, 2015, 7:46 am
Briggs wrote:
Budget? 120V, 220V?
well whaddaya know. I've got the northern MIG135, that I found new-in-the-box on Ebay for $180 delivered. thing is a stout workhorse. did everything on the B-3 but the driveshafts. borrowed a lincoln 180 for those
PostPosted: April 29, 2015, 7:53 am
Have you considered the wire feed units that run off the arc welders transformer? I have one and its nice and light. just need long leads and a gas pipe.
http://www.migtigarc.co.uk/MIG_Welder/M ... _unit.html
Bob
