Good info guys - thanks. The thought of making one is intriguing but since I'm doing multiple panels on a body I'm guessing the HF 110v unit won't have enough juice.
The HF one is also rated for a 110v/13A supply. The weakest Miller one is 110v/30A. That probably explains why the HF one falls short on big projects. If I had easy access to 220v I'd be set. My 4000 watt generator has a 220v plug but I don't think 18A will be enough to run a welder.
mkejim wrote:
If you were closer I'd lend it to you but its heavy and shipping would be terrible.
Thanks for the offer Jim. If you were local it would be a different story.
I'm probably better off just plug welding and griding.
