It is currently February 25, 2020, 5:41 am
 Post subject: Adjustable cam gears
PostPosted: August 26, 2016, 7:15 am
So with the upgraded cams my motor has, I need to have adjustable cam gears to get them in timing. And it is my nature to want to make my own. But I want to do so by saving some time.
So, I plan to machine out the center and drill holes for stainless PEM Studs. Then have an aluminum center lasered out then finish the machine work on it myself.
I have a Bridgeport mill mill and a lathe to get the job done. And I work at a place where I can get the aluminum section lasered for free. The press in PEM Studs I already have as well. So I can have an adjustable set of cam gears for zero cost, if I do this right
Is there any reason my design is a bad idea? I welcome ANY type of information here. I'm a rotary guy. And making piston engine parts is somewhat new to me.
I attached a few Jpegs of the design. (I'm a Mechanical Designer by trade. Former Machinist. Former Welder)
1st is the Aluminum Center
2nd is the Modified Stock Cam Gear
3rd is the stock Cam gear untouched
 Post subject: Re: Adjustable cam gears
PostPosted: August 26, 2016, 7:18 am
Here are 2 more pics of it assembled. One photo of the front and one of the back.
PostPosted: September 1, 2016, 6:29 pm
Your center section looks a little thin but other than that I think it'll work fine. Might want to do all steel and do a few larger lightening holes rather than many small ones just due to the number of cycles that gear will see.
I'm running a Vernier cam gear on my Sprite and it a nearly identical concept. Works just fine.
