It is currently January 29, 2020, 11:51 am
PostPosted: December 5, 2013, 2:31 pm
I am trying to find a source for affordable rectangular fiberglass tubing, to build a lightweight car frame out of. I got some samples years ago while trying to compete in the Auto X-Prize, and the material is very light and strong. The big manufacturers will not discuss less than 1,000 feet at a time. Any suggestions? Thanks!
PostPosted: December 5, 2013, 3:28 pm
Is there any reason why you couldn't use round tubing? It seems like it would be much easier to source.
PostPosted: December 5, 2013, 4:32 pm
Google finds several, here's one
http://www.eplastics.com/Fiberglass-FRP ... are-Tubing
PostPosted: December 6, 2013, 7:47 am
Unless you intend to use carbon fibre then aluminium tube is lighter for the same strength.
Otherwise any good fibreglass shop can just wrap polystyrene square lengths to order, it's not rocket science.
I think there's some relative info for you in this thread .. viewtopic.php?f=39&t=15283
PostPosted: December 7, 2013, 7:57 pm
Yes, and while 2/3 the weight of aluminum, fiberglass is only 1/3 as stiff and that's if you use pricey S glass.
And steel has the same mass/stiffness ratio as aluminum, so why not use that?
And the metals absorb a lot more energy in a crash.
Noah
PostPosted: December 8, 2013, 4:55 am
It's relative to buckling strength as well but at the safe thicknesses of a Locost chassis, yes, steel is the winner when all the sums are done and that's why even the most expensive Caterhams etc. chassis are still done in steel.
PostPosted: December 8, 2013, 1:03 pm
Online
It isn't the absorbing that is different it is the dissipation! :D Think an Olympic pole vaulter. The tube absorbs the energy but then it returns it during spring back. Worst case a Locost chassis of fiberglass would hit a wall and then launch you backwards at the same speed…
I'd like to see an option for doing the car from Aluminum. Corrosion resistance would be a nice to thing to have in at least some parts of the country. The sums clearly say aluminum wins hands down over steel from a mechanical perspective. It's a hard problem though when considering labor. You see aluminum in planes because weight is much more important for planes than cars. In a Locost the frame and body are also a smaller percentage of the total weight so it becomes evan less important.
Steel is a good material for us because it is very well understood with 50 years of Seven type construction and is forgiving of average builder skills. It also lets you think you are 50% done after building your frame when in fact you haven't even learned how to figure out "done" yet. :rofl:
PostPosted: December 10, 2013, 12:30 pm
Here you go, provided on the usual platter: http://www.mgs4u.com/fiberglass-tube-rod.htm
PostPosted: December 13, 2013, 1:44 am
That's true, because of its low modulus and relatively high strength fiberglass is a relatively good energy absorber/spring material (i.e. Corvette suspension leaf spring).
But you don't get much of that benefit unless you build a low stiffness frame.
Noah
