Thanks for the discussion so far. Keep it coming.
Having examined the way seat belts are sewn together it doesn't look like a very hard thing to do to me.
I have shortened seat belts before. And I agree, there is nothing other than a good machine and the proper needle / thread required to do so. Getting any required approvals, (not for me BTW) would be difficult.
The Birkin has a standard inertia 3 point belt with the inertia reel outboard. The reel is mounted low on the rear bulkhead, but in a recess so that the belt runs parallel and near to the bulkhead, without the inertia reel interfering with the seat.
It would be ideal I guess. I have no space for mounting them in the cockpit as my seat back sits flush against the bulkhead and there is zero space alongside my seat squab. Maybe, had I thought this out a bit earlier......
he demonstrated how it is important to stop the acceleration of the lower body first, then the shoulders
Makes a lot of sense. I think my fixed 5-point does not allow for that, hense the 5th anti-submarine section.
My concern with such an arrangement is that in a frontal impact, if the bodies were to twist, both the driver's and passenger's heads would be directed towards each other as their upper bodies rotated.
point taken. I have looked at some crash videos from pre-airbag periods. In most of those crashes, the driver does not rotate. I think it has to do his ( His? Do crash dummies have gender?) head slamming into the steering wheel dissapating all the energy before coming to the full extension of the shoulder belt. The passenger seems to have a 50-50 chance of rotating upper body outboard. From what I have observed, even when the torso twists, the head only rotates sideways. It seems to still move directly forward. But I am just a layperson with 15 minutes of expertise. I'm not a professional crash expert.
I think that in all the the current cars with airbags, the airbags play a big role in controlling any upper body twist. I really don't think that inboard or outboard shoulder mounts make much of a difference with them.
I am really leaning towards (no pun intended) the central mount inertia belt. I still have a month or so before I start to think about changing things over. So keep the discussion going.
