The only quirk is, if you're attaching a series of photos, you have to upload the last one first and work your way back to the first one.
Jack, the photos can be uploaded in any order. Once uploaded, there is a command window just below the message body window that allows the photos to be inserted anywhere, even between text. They are listed in a drop-down window by filename. One could easily insert the first photo then the third, then the second if you have a mind to. The photos show up in the location that the curser is in when"inserted". That command window doesn't show up until the first photo is uploaded.
I'll have to look at reducing the filesize even further. I thought I was doing good at <100Kb. Thanks.
One of the nice things about using the snipping tool is that the photo shows up on these pages the actual image size that was cropped. If you "snip" a photo at 1/2 screen size, that is the size that shows up in this forum. Before settling on Snipping tool, I tried many ways using MS Picture Manager in which I could control the file size via JPG compression and pixel size, but never found a way that produced an expected image size on this forum. Sometimes they showed small and sometimes they were very large images. Just my ineptness I perhaps.
