mjalaly wrote:
you mean the main rear suspension box tube! No way. Not worth it for aero.
when I ran a quick sim on it that was the problem .
it's just all flat to a sharp roll so it's diffusing any of the air in fact it's adding more surface area for the air to grab hold of .
air acts as a fluid so as the air is exiting off the rear it has surface area to run up on .
it's better with it just cut straight across air does lap over the edge some but there is nothing for it to grab hold of .
another option is to extend the diffuser out the back of the car but the down side to that is you would have to extend it but at the least 15" and that's just guessing as I don't really know the measurements of the under side of the car I'm just guessing at it from tire size .
it would also have to go much wider right up to the insides of the tires .
another problem with diffusers that stick out way past the rear of the car is departure angles .
you will be dragging that thing on the ground all the time . it's ok for track only use but forget about using it on the streets .
with the drive line in the car I would like to see the air flow over and around it . this will have a very big effect on the efficiency and design of the diffuser .
