basfromasd wrote:
rapt wrote:
Fitting a sliding window inside a thin door is notoriously difficult.
The easiest solution would be to use the 2cv mechanism: a two-piece window, of which the bottom half is hinged in the window frame. You can flip it up, where it is held by a clamp. Simple, proven and you can still rest your elbow on the door.
The 2cv hinge appears to be right in the line of sight.
If one didn't tilt the upper side inward above the belt line, a channel just like a house window to slide up and down would work. Lever or gear silding with several detent positions would work. With a single lever/cable pull, it could be operated while in motion, leaving a hand on the steering wheel.
I like the sliding setup on the Messerschmidt; just aluminum channel and a finger grip. The Morgan uses a similar arrangment.
Ford IFS
