Yeah, there is no perfect location (other than in an armoured casing... but not with the electrical in the same one
In most of our cars there is not enough power/traction to break driveline parts so I would say the tunnel is the best bet. Just a driveshaft loop, and good quality shaft and u-joints is what most people feel best. You could weld a thick tube inside the tunnel, and then run the fuel lines through it if you are concerned.
On a drag car where driveline failures are likely I wouldn't pick the tunnel. But on a lightweight sports car (where crashing or bottoming out are more likely) the tunnel seems safest.
Cheers.
Cory
