routes for wires, lines, tubes, cables, etc? http://www.locostusa.com/forums/viewtopic.php?f=27&t=18541 |
Page 1 of 1 |
Author: | geek49203 [ September 26, 2016, 9:26 pm ] |
Post subject: | routes for wires, lines, tubes, cables, etc? |
My former neighbor ran a Triumph in SCCA racing, and things got real exciting when his fuel line -- run inside of the cockpit -- rubbed thru and ruptured. Then again I can imagine things getting real interesting if something happens to the driveshaft, etc if you run stuff thru the tunnel. Where did you run your fuel lines, brake lines, and wires that had to go from front to back? Thanks! Tim |
Author: | KB58 [ September 26, 2016, 10:07 pm ] |
Post subject: | Re: routes for wires, lines, tubes, cables, etc? |
There was a fairly extensive thread on that here several months ago. |
Author: | FieroReinke [ September 27, 2016, 8:59 am ] |
Mine is through the tunnel with the brake line and the wiring, but there is a 1" drive shaft hoop between the gas line everything and the drive shaft. |
Author: | nick47 [ September 27, 2016, 3:39 pm ] |
Tunnel. So far so good. |
