Searching for answers. Please post pics of your fuel tank
Radiator, plumbing, fuel pump, fuel injection, exhaust, manifolds, and anything else that keeps the motor happy.
doommachine
Building: lotus seven kit
Post by doommachine »
I am struggling with picking a Fuel tank, and location for it. My build is IRS miata based. There is space above the diff for a 8 gallon tank about 8" high, or I can fit something in the stock location.
RCI 15 gallon
Jaz street Rod
Both of those do not have baffles or a sump
Jaz 8 gallon 20x15x7.5 with sump could fit on top of the Diff and has a sump to help against starvation, but that puts the tank at deck height and would complicate the vent I suppose, short of running an ugly tube up the roll bar brace.
What about those spun aluminum tanks that could fit well in stock location but would need some extra fittings installed.
I would love to have one made, but California is not the place you want to be paying shop labor rates, and I don't have the ability to weld aluminum myself.
Lonnie-S
Building: V6 Powered Locost
Re: Searching for answers. Please post pics of your fuel ta
Post by Lonnie-S »
Do an Internet search. I've seen outfits that make custom tanks in aluminum out there.
doommachine
Lonnie-S wrote:Do an Internet search. I've seen outfits that make custom tanks in aluminum out there.
Can't spend 500 bucks on a tank and I have been all over the internet. I may put a call into RCI since they will do custom stuff. But the price can rocket up quickly I am sure. That is why I came asking from the people that have done it.
RTz
Post by RTz »
WARNING not low cost…
I’ve run this set-up hard down to 1/8 of a tank with no hiccups. I sent a crystal clear drawing of what I wanted to Boyd Welding in Florida and they built the tank with a filler neck, sending unit and an Aeromotive Phantom pump/sump unit. The location is same as a Caterham. It has two baffles separating the tank into roughly equal thirds. The sump has 4 check valves 90 degrees apart at the bottom and the return pumps directly back into the sump, in theory, keeping the sump at a higher level than the tank when low on fuel. With some effort it could be replicated by a creative DIY’er.
Peace, Ron
Lonnie-S
Post by Lonnie-S »
@doommachine
Yes, I understand. As a suggestion, try reaching out to Perry (@horchoha) or Chuck (@rx7locost) by PM and ask for a link to their own efforts in their build logs. I know Perry has done multiple tanks in steel and I'm pretty sure Chuck did one too.
You could do the basic fab work yourself and just tack weld the pieces in place leaving the final welding to a professional. You can do the bending without a big brake using simple things like angle iron and wood.
Once welded and tested, the inside of the tank is best coated with some materials that can be had at Eastwood or other, similar firms. It is a user do-able process once you know what to buy. I haven't used them as I bought the JAZ tank, which is a poly material that doesn't require treatment.
There's always a solution to these problems.
KB58
Building: Midlana
Contact:
Post by KB58 »
Go to my build diary, here, https://midlana.com/2015/02 and read the 1 February entry. You are building a car - you can also build a gas tank.
doommachine
KB58 wrote:Go to my build diary, here, https://midlana.com/2015/02 and read the 1 February entry. You are building a car - you can also build a gas tank.
that looks like a fun project, but not sure if it would save me any money and how do you keep the welds from not rusting in the tank. I pondered using 20ga stainless and making my own tank. I think if I had access to a water jet I would do that, but shop rates out here are 150 an hour. just to have the metal cut they would charge me that I imagine. VS an ebay JAZ clone with sender for less than that. The cost of Labor here is pretty high, They charged me 400 dollars to do 6 tubing bends on my roll bar and rear structure.
davew
Building: 4age locost
Post by davew »
If the $$$ is the problem, I would look at making the tank from mild steel sheet stock after a good cleaning of the surface. I used plated steel, but ground back all the welded seam areas, and left the seam area un-coated. If using mild steel for your gas tank, it is a good idea to plan on changing the fuel filter on a regular basis. I would cut open 1st the filter change, to see the amount of rust and scale has been collected, which will help on judging the frequency for filter changes. I retro-fitted a gated sump on my tank, and it had no visible rust in the seam areas. I did have some particles on the pick-up socket which I contributed to the gas station tanks. I changed the first filter around 4,000 miles, I'm on my 2nd fuel filter with over 65,000 miles.
KB58
Building: Midlana
Contact:
Post by KB58 »
It's a stainless tank, so no rust. High labor rates are exactly why I did as much of the work myself. Use a jigsaw and cut it yourself. I know that it sound flippant, but you can do it. Sure, it'll take longer, but there is - should be - no deadline to having the car done. Remember, the journey is the adventure.
doommachine
I could be open to making my own Stainless tank. Will see if good options make themselves apparent before I get to that point. Ebay options are ok and could be a stopgap at some point. Aside from needing to run line and the final rear section design somewhat dependent on it, there are many more pressing steps.
jaf
Building: +221-Haynes-Miata
Post by jaf »
JAZ tank with foam sitting above Miata diff. I used all Miata fuel parts, modified fuel pump, roll over vent, sender, etc.. See build page for details.
doommachine
jaf wrote:JAZ tank with foam sitting above Miata diff. I used all Miata fuel parts, modified fuel pump, roll over vent, sender, etc.. See build page for details.
Which tank is that?
jaf
Post by jaf »
Which tank is that?
JAZ 8-gal.
https://www.summitracing.com/parts/jzp-250-008-nf5?seid=srese2&utm_source=bing&utm_medium=cpc&utm_campaign=Brands+|+J&utm_term=4581252645114315&utm_content=GSAPI+5cc9f06108d3d
Miatav8,MstrASE,A&P,F
Post by Miatav8,MstrASE,A&P,F »
Stainless does not mean rustproof. Avoid 4xx series. This is what "cheap" stainless outdoor grills are made from.
An unbaffled tank can be used with a small tank acting as a sump for the pump. The sump tank can be anywhere you have room outside the interior. A return line system would return to the sump tank, helping to keep it full. There are a number of ways to do it. I prefer a poly tank. Return systems are for carbs too, not just efi.
doommachine
They don't even sell that junk. My steel supplier has mill grade and polished stainless. I didn't get polished because it was significantly more expensive. I have so many projects in this build, what is one more
