Thanks for the comments guys. It's been a fun journey so far.
MV*8, the last photo shows the most roll that the car has seen thus far. I am sure HPDE days around Dallas will push it a bit more. The exhaust can and tip are flush with the bottom of the frame. It just looks lower because of the angle of the photo.
I have my 1/8 SS rod for the grill frame and "7", I just need time to build it. It will have a screen mesh for bugs, and a radiator shroud to focus the air through the radiator.
Those are the free wheels that came from my 1999 AE Miata donor, they will be sold once I make a final decision on wheels (and budget allows). The fenders will work just fine and look correct with the appropriate sized wheels, tires, and possibly a spacer depending on the rim width I decide on.
This is a 442e, with Lotus Elise seats, and Caterham rear fenders. I have CSR fenders for the front, but didn't want to waste time building brackets for the small Miata wheels. Yes, NB donor. I just wish I had listened to the voice in my head saying make the tail end higher. It is a little too low from the side view.
The windscreen will be custom, as it needs to look appropriate with the roll bar height. I wanted to be sure my head was well under the roll bar (I'm 6'3"). I also don't want to have to look through the top windshield frame to see signal lights. My dad's FFR Cobra has the top frame right in line with most signal lights when you are on the stop line. You have to crane around to see the lights change. I will make a bikini top like the Jeeps use, but will not use doors. I will have wings to help with the buffeting, but I can live with that. I've already been rained on 5 times in the last few days driving it out to the Smokies, then out to Dallas on Monday. It wasn't so bad. Mostly, I would just like the sun off my neck for long drives.
I built the dash to house that cluster.
I can see everything I need to on the cluster in the seated position, even with the 280mm Momo Team that is on the car now. I do have an NRG quick release, so steering wheel options are a possibility, but the steering effort is not bad with the small wheel at this point. We will see once I have a little more tire on it.
Most the engineers I know are being picked up locally. There are plenty of companies looking for those experienced folks.
