seattletom wrote:
Marcus,
That's a really creative structure for mounting the diff and I like the bobtail look (...on the car I mean
A builder could always add a light (aluminum?) sub-frame if they wanted to support longer rear bodywork (like a Seven, or perhaps a boat tail.) But the truncated look appeals to me.
Is that an 8.8 Ford diff you have in there?
When I shortened the rear facing hoop, that's just structure. I don't mean to prevent the normal rear end look. I meant to mention that. This would probably allow a little more variety now because you can just use some light tubing or sheet metal to work up any shape you want.
The picture is a little premature, it has parts of a previous effort and parts of the new effort. I am going to to try and bring them together the next day or two. It's missing the crucial tube from the place where the braces meet at the rear hoop to the rear diff mount. That will triangulate ( somehow ) with the tubes coming in from the sides which are supporting the rear suspension parallel links.
I was reflecting today and can see the traditional Seven / Locost rear bulkhead with it's backwards slant might make this a bit easier. You could maybe get support from above on the cross piece behind the driver's shoulders. I am trying to keep really major lumps out of the passenger area and also not have metal tubes pointed at the passenger's backs. So that will get some attention the next day or two also.
Thanks for the pointer on "B85", I'll go try and find his build log. If it adds a bit to what I got from Oldejack's pointer, I should be able to draw something up. These drawings are going to have 20-30 layers and you'll be able to just click on parts and configurations then see them appear in the chassis.
The diff in that picture is a Ford 7.5". It's very similar to the 8.8", for instance I believe it has the same length and front mounting. The 8.8" has a pinion offset of 2" instead of 0.5".
I hope I don't run out of places for a fuel tank. I think a drum on a little trailer is probably just wrong some how...
