It is currently April 18, 2024, 10:08 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2, 3  Next
 Post subject: Locost critique ....
PostPosted: May 29, 2012, 11:10 am
Read till the end (4 short pages) ...
http://www.formulastudent.de/academy/pa ... his-stuff/
 Post subject: Re: Locost critique ....
PostPosted: May 29, 2012, 12:26 pm
Interesting read.
At the end he showed examples of things wrong, but not any solutions, bummer.
PostPosted: May 29, 2012, 1:14 pm
No solutions but very interesting nonetheless. Thanks for posting it.
PostPosted: May 29, 2012, 2:08 pm
Well he didn't actually say to always use DOM for bushes but he did mean it ....
"Often the well meaning amateur will use welded steel tube to make this pivot and eventually, this happens..."
PostPosted: May 29, 2012, 3:10 pm
His context is education for students.
Particularly in the case of the pushrod, it would seem to make sense to make the bracket part of where the ball joint bolts on. Make the bracket so that it bolts on top of the ball joint and sandwiches it. With the pushrod you would be less constrained by something like the length of the available shocks...
It would be nice to see a much closer up picture of the failed front wishbone bushing. It should be welded with the wishbone arm across the seam in the bushing tube. If it failed at the bushing tube's weld seam, even a seamless tube may have been marginal. Perhaps in the future he will do some more extensive failure analysis and still not have to provide the solution. Understanding the reason for a failure is obviously key - then there are many things you could do to avoid that mistake.
PostPosted: May 29, 2012, 4:30 pm
It looked to me like the wishbone failed because of the sharp edges on the shock support plate. Big stress riser there. Nothing to do with the pushrods. The inner edge of the shock support plate needs to be curved, so the arm can flex a little.
PostPosted: May 29, 2012, 6:11 pm
If you mounted the pushrod or shock at the balljoint bracket, then there would be very little load on the wishbone. I didn't explain it well. There would be less leverage and also the bracket or thick plate on the ball joint support would carry a lot of the load.
PostPosted: May 29, 2012, 6:17 pm
If it were my pushrod build, I'd be offended that this guy is comparing them. Apparently he cannot see the difference or what the primary issue is.
Yes, the arm could be greatly improved and should be, then reinstalled and break again due to the actual issue with the suspension bottoming out (coil bind). It appears to have about 1 inch in bump.
Welded tube did have some issues splitting at the seam back in Pat's day. Nothing wrong with welded tube.
Also, DOM is welded tube. Note the discoloration down one side.
On the second "example", the control arm pivot appears to have used too thin a material, flexed back and forth at the stress "notch" where it joins the arm, then failed. Given the use of expensive oval tubing, I very much doubt the builder would have used welded, but is more likely to go with too little wall thickness in 4130 to save a gram on a part that barely moves.
Pat should try cornering something else.
PostPosted: May 29, 2012, 7:54 pm
Kinda my thought on that pushrod / internal shock setup -- where is the bump stop? AT some point (about 4" above the rest height?) that bell crank at top won't allow that push rod to go any further in the "up" axis, and bad stuff is gonna happen. Either the bottom of the rod will do something bad, or the bell crank at top will be ripped off, or the push rod will bend.
Unless of course the frame/motor is supposed to bottom out on pavement before the crank's travel is at maximum... even then, you still have the potential of some large upward movement of that front tire where the frame won't be on the ground (ie, hitting a big rock or curb or something).
What is confusing to me is how the situation I'm envisioning would lead to the breakage of the (spindly, thin) LCA, on a setup that doesn't have inboard shocks? How are those two situations all part of the same mistake? Is he assuming that the shock mount will act as a pivot point under a sudden shock, and the LCA will break as it is bend downwards?
G'03
PostPosted: May 29, 2012, 11:27 pm
Yes it is but it's further processed to stop that weld being the weak point.
It's fine for main chassis or kitchen table legs but not good practice to make suspension components out of ERW. Note all the world's various motorsport governer's spec for roll bars is DOM.
Pat Clarke's resume is quite complete.
PostPosted: May 30, 2012, 1:04 am
It doesn't really matter how impressive his resume is. While many of his observations are indisputable, the most of the conclusions he draws from them regarding the Locost community seem to be heavily prejudiced by gross generalizations at best...And patently false at worst. Having placed himself high upon a pedestal he has completely missed, or maybe just totally misinterpreted, the intent behind the Locost car and the Locost community, as well as its place within modern motorsports clubs. This not only does a disservice to the entire Locost community towards which he speaks with such condescension, but also in my humble opinion diminishes his credibility as a potentially useful source of unbiased information.
PostPosted: May 30, 2012, 9:13 am
I'm glad you posted about the DOM being welded. I had an argument recently with a fabricator friend. He was adamant the DOM was not welded. I once worked in a steel mill in Chicago and knew, but my friend was not convinced. It is welded and then drawn over the mandrel to eliminate the effects of the weld.
PostPosted: May 30, 2012, 9:31 am
Don't mean to hijack this thread but here is some info I found on steel
Here is a post from BillaVista, I am NOT taking credit for this wealth of knowledge-
Steel Tubing
It is impossible to go into details about every type and shape and grade of steel product available or that we might be interested in. There are far too many, and availability will vary greatly depending on location and manufacturer/supplier.
That said, one of the most often used, most often asked about, and most often misunderstood products we use is the venerable round steel tubing.
Round steel tube is commonly available in a number of industry standard sizes. For an idea of the common industry sizes (inside diameter (ID), outside diameter (OD), and wall thickness) browse the supply catalogue of your local supplier or check the Pirate4x4.com tech database HERE and especially HERE.
Note that round steel mechanical tubing is NORMALLY ordered and supplied based on a specified OD and wall thickness. The ID is the result of these former 2 specs. There are however some exceptions to this - most notably in true seamless tubing.
Here are some Flash™ graphics of the different steel tube forming processes that I snagged from the excellent Steel Tube Institute of North America website.
Contnuous (butt welded) pipe process.
The continuous process produces a full range of pipe sizes from only a few different widths of skelp. The coils of skelp, or strip, are fed into the mill and their ends welded together to provide a continuous flow. The strip passes through a pre-heater and into a furnace. The heated strip is shaped into an arc of about 270° in a forming stand before passing into the welding stand. There a nozzle applies oxygen to the edges to further heat them as they are pressed and welded together. The pipe's OD and wall thickness are reduced in a stretch-reducing mill. Pipe is then cut to length, reduced to the required size in a sizing mill and water-cooled before being straightened. It is then ready for finishing
Typical Electric Resistance Welded tube process
Steel strip is unwound from coils and side-trimmed to control width and condition the edges for welding. The strip then passes through a series of contoured rolls which progressively cold-form it into a circular shape. The edges are forced together under pressure and welded by heating the steel to temperatures between 2200° F and 2600° F using copper contacts or coil induction. Weld flash is removed from the the inside and outside surfaces of the newly-formed pipe, and the weld zone is heat treated to ensure homogeneity between the base metal and weld. The weld is subjected to in-line nondestructive testing, and the tube then passes through a series of sizing rolls to attain its precise finished diameter. It is then straightened and cut to the desired finished length.
DOM tube being constructed, starting as ERW and then being drawn over a mandrel.
The manufacturing process for DOM tubing begins with coils of steel, which are slit to the proper width for the desired tube size. The strip is cold formed and passed through an electric resistance welder which joins the edges together, under pressure, to complete the tubular shape. After testing the weld's integrity, the tubing is cut to length for further processing
Seamless tube construction
The production process for seamless tube begins by heating a steel billet to about 2250° F. The red-hot billet is rotated and drawn by rolls over a piercing rod, or mandrel. The action of the rolls causes the metal to flow over and about the mandrel to create a hollow tube shell. After reheating, the shell is moved forward over a support bar and is hot-rolled in several reducing/sizing stands to the desired wall thickness and diameter. The tube, which has grown significantly in length during the piercing and sizing processes, is then cut into sections and conveyed across a cooling bed to cool slowly in the air. It then receives whatever finishing processes are needed to meet customer requirements.
Steel tubing is usually supplied in one of the following forms:
Seamless Tube.
This is expensive and specialized stuff. It IS NOT the commonly used (and misreferenced) DOM tubing, as DOM tubing does indeed have a seam (albeit, almost invisible - more details below). True seamless tubing is uncommon in 4x4 and automotive use. It is seamless because it is manufactured by a process know as "extrusion" where a solid bar of steel is pierced down the center with a die, at unthinkable pressures, to form a tube. The process looks similar to how hollow pasta (macaroni etc) is made. There are 2 sub-types of seamless tube:
Cold Drawn Seamless (CDS) Tube is normally drawn to O.D. and I.D. dimensions and produced to standard dimensional tolerances (this differs from most other types of tubing except DOM) . It is normally made from SAE 1018 and is considered good quality.
Hot Finished Seamless (HFS) Tube is lower in cost than cold drawn and most applicable where precise dimensions and surface quality are of secondary importance. It is manufactured to O.D. and wall dimensions from SAE 1026 steel and is scaly, less dependable and not as strong as cold drawn tube.
Electric Resistance Welded (ERW) Tube
ERW is the most economical and readily available type of mechanical tuning. It is produced by taking a flat bar of steel and rolling it into a tube shape (picture rolling up a newspaper - but without any overlap) and then welding the seam - by, you guessed it - electric resistance - hence the name. Electric resistance welding is somewhat like a long, continuous spot weld. It's often computer controlled and extremely consistent. ERW is normally SAE 1010 (for wall thickness < 16 ga) or SAE 1020. ERW tube comes in 2 flavours:
Hot Rolled ERW (HREW)
HREW is rolled into a tube at elevated temperatures, usually way above room temperature. This produces a tubing that is more malleable and therefore easier to form but that is also not as strong, is supplied covered with scale, and not as uniform in dimension as cold rolled. It is also quite a bit cheaper than cold rolled.
Cold Rolled ERW (CREW)
CREW is manufactured by a process in which a steel bar is rolled into a tube and the seam welded, usually at room temperature. Compared to hot rolled, CREW is stronger - (greater yield strength) - because of the improvement in the crystal lattice structure from improved grain size, shape, and orientation imparted by being worked at cold (room) temperatures), straighter, has a much smoother and more uniform surface finish, and is made to much tighter, more consistent dimensions. It is the best economical choice for tube work, and because of the better surface finish and tighter dimensional tolerances it is much nicer to work with than HREW.
Drawn Over Mandrel (DOM)
Strong and well-finished DOM is an electric resistance welded tube tested for soundness of weld and drawn through a die and over a mandrel. This process imparts significantly improved mechanical properties to the tube, due to the cold working process. It is considered a high quality tube, and is normally constructed from SAE 1020 or 1026 steel. Note that, technically DOM refers to the process by which the tube is finished after having started as an ERW tube. Technically, DOM is not a type of steel tube, but rather a process. As so often happen though - in common use the term has become accepted to mean a specific type of tubing rather than a process. In this case, when people say "DOM" they normally mean an ERW tube drawn over a mandrel at (close to) room temperature and made from SAE 1020 steel. It is normally drawn to O.D. and I.D. dimensions. Here is what the Steel Tube Institute of North America has to say about DOM:
The DOM Manufacturing Process
The manufacturing process for DOM tubing begins with coils of steel, which are slit to the proper width for the desired tube size. The strip is cold formed and passed through an electric resistance welder which joins the edges together, under pressure, to complete the tubular shape. After testing the weld's integrity, the tubing is cut to length for further processing.
The cold-drawing process creates a uniform, precision product with substantially improved tolerances, surface finish and tensile strength, increased hardness and good machinability. In this process, the tube is cleaned and annealed, and one end of each length is squeezed to a point so it can be gripped by the drawing mechanism. The tube is then drawn through one or more dies and over mandrels. This reduces the diameter of the tube and thins its walls to the required dimensions in a controlled fashion to provide the qualities desired in the finished product. Metallurgically, drawing improves the tube's concentricity, tensile strength, hardness and machinability. Close dimensional accuracy is achieved through tight control of both outside and inside diameters.[10]
Alloy Steel Tubing
Is not really a different type of tubing, as it will be manufactured by one of the above described methods, usually by extrusion, but from alloy steel instead of mild steel. It is generally available in either the normalized or the annealed condition. Commonly referred to as chrom-moly tube - it has very strict welding process and post-welding heat treatment and stress relieving requirements. It is my opinion that it can (should) only be TIG or Oxy-Acetylene welded, and then only if proper stress relieving will be done post welding. Sure people MIG weld it all the time, and you can safely do so - BUT - what you have in the end is a superior tube with an inferior weld joint which reduces the overall strength of whatever you fabricated to the weakest link (the weld in this case) and so you have a very expensive structure that is no better overall than one made from 1020 DOM.
Exact chemical content, heat treatment, physical properties, production method and therefore mechanical properties will vary from one supplier to the next, even for seemingly similarly named products - the wise fabricator double-checks all assumptions carefully before building anything. Different suppliers will also have available different products. For example, Ryerson-Tull, one of North America's largest suppliers list in their catalogue of steel tubing between 1" and 2' OD, the following types (not all available in all sizes):
CDS, HFS, DOM, ERW, and a proprietary product they call "Ry-Star 512 Extra".
Many suppliers will have such special proprietary products - you will have to check with your supplier for its proprietary product properties and specs.
One thing that has to be watched out for is that the industry bends a lot of carbon steel tubing to make lots of things and so most carbon steel tubing is available in the annealed condition—woe to him who does not detect it before he builds the part. I have a very good friend who once got an entire roll cage cut, bent, fitted and tacked before he realized that his merry men were working with annealed boiler tube. The other thing that we don't want is "free machining tubing." I currently use round carbon steel DOM mechanical tubing for most things other than suspension links (there I use E4130N and stress relieve and heat treat after welding). For roll cages I use either 4130 or DOM 1020. I do not want to know about hot-finished tubing because I do not want to clean it. I am old enough to remember the days when English ERW tubing was liable to split along the weld seam. As a matter of principle (or, possibly, stubbornness) I do not use ERW or butt welded tube on the race car; although, since it is a lot cheaper, I use it all over the trailer and the shop.[11]
My personal mantra on the subject of steel tubing choice for 4x4s and rock crawler's is:
"You can't go wrong with 1020 DOM!"
__________________
PostPosted: May 30, 2012, 10:51 am
I've never seen ERW tubing fail in a Locost without "help" - bottoming suspension, hitting another tube, etc. OTOH I have seen suspension brackets fail that were cantilevered off the edges of tubes, as is seen in one of his pictures.
PostPosted: May 30, 2012, 1:22 pm
Heres the Google results, they speak for themselves, no professional or serious builder uses ERW for suspension components, do you recommend ERW for suspension components in your books?
ERW lower control arms ...
http://www.google.com.hk/search?hl=en&n ... SKH4ktzhmc
DOM lower control arms ...
http://www.google.com.hk/search?hl=en&n ... JgkALBL73M
If I remember I'll run a direct comparo between 30 x 1.5mm DOM and 32 x 2.0mm ERW tomorrow.
