It is currently May 19, 2019, 7:02 pm
Forum rules
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: October 14, 2014, 7:42 pm
DaveStruve wrote:
Briggs wrote:
You doing ok down there?? You avoiding the weather?
Lots of rain and some thunder. Not much else. May be filling a seat in a 10hr kart race this weekend.
Thats good to hear. Wheres the race being held at?
PostPosted: October 14, 2014, 7:45 pm
Home track, Atlanta Motorsports Park through endurancekarting.com. Its an arrive and drive deal, did the same race last year in the rain on slicks and it was rough. Hoping for dry weather this time around.
1 year of neglecting my wife and children and all I got was this car... Totally worth it.
viewtopic.php?f=35&t=15496
PostPosted: October 20, 2014, 11:27 am
Just perfection!! Great build!!
PostPosted: October 28, 2014, 8:57 pm
So another big milestone today. I had yet to write about this, but a month or 2 back I started worrying about emissions. As the car is titled as a 91, I still needed to get through this years test in December in order to be clear through next year and hit the 25yr exemption in 2016. My contact in the DMV said they would be able to assist with getting an exception however they went dark a few months back and I had no idea what was going on with it. So last month after not hearing anything I started to worry and decided to take it to get a emissions test done and get a base line. It of course Failed. So with the failure info, I took it to my tuner and requested that they tune it to pass. Which they did, and it failed. It failed better but not anywhere near close enough. SO I really started to freak, I started researching registering it out of state under a LLC, and any other loop hole, since I didn't really know what would fix the issue. Thankfully though after failing the second time and leaving a obviously freaked out message with my contact, they finally called me back last week and told me it would be fine and that I would just need to come see them and they would push it through without the emissions. Well since you can renew within 60 days, I decided to not take any chances in case this wasn't true and do it today. And ladies and gents, drum roll please... I am clear car is registered for 2015 and thus clear of emission from this point forward, should even be able to get a historic plate next year. Huzzah
PostPosted: October 28, 2014, 9:38 pm
Good to hear Dave!!
PostPosted: December 30, 2014, 5:43 pm
Dave,
Superb car you have. It is just.....right!
Link to my build log:
PostPosted: April 13, 2015, 5:04 pm
Thought I would do a "State of the Locost".
I've had a few updates:
- Installed one of these (http://www.solarcapitalist.com/sae2pin- ... ended.aspx) on my dash under my steering wheel. basically this allows me to plug my trickle charger directly into the dash, thus I no longer have to take the hood off after every drive.
- A few weeks ago I did this while launching it.
Not sure if it was from the launch or missing 3rd gear and hitting 5th. But I snapped the arm clean off. I was still able to drive it home though. Following day I pulled it out and had it welded back up and boxed in. I may still go back and install some aluminum bushings.
- Finally, my braille battery crapped out on me. May be because I wasn't running an alternator until recently. But thats another thread entirely. Unfortunately the warranty had expired, but they were nice enough to discount a replacement. Hopefully this one lives longer that 1500 miles.
PostPosted: April 14, 2015, 6:08 pm
Looked through your build log.........no pic of how the nose of the diff was mounted. Can you enlighten us? Thanks.
My build http://www.locostusa.com/forums/viewtopic.php?f=35&t=7370
PostPosted: April 14, 2015, 6:13 pm
Must have left that out of the build log. Basically the large steel bracket is bolted to the chassis.
PostPosted: April 14, 2015, 7:20 pm
I was reading a post yesterday about another guys Miata diff that failed in the same place. It might be something to look at strengthening if anyone else has one.
Car looks great by the way I love the Supercharger Whine
PostPosted: April 14, 2015, 7:52 pm
He had a welder fix it and added gussets to make it stronger if not mistaken.
PostPosted: April 14, 2015, 8:16 pm
Yep, its a designed failure point on the diff arms. Supposed to break in event of a rear end collision. I would recommend boxing it in advance if a car is being built with this diff. It alot easier doing during the build than after a failure. I had to dissasemble most the the rear of the car to gain enough clearance to get it back in.
PostPosted: May 9, 2015, 9:51 am
New Photos I found online:
Videos I found Online:
https://youtu.be/onhC-Fp6Bqo?t=3m24s
https://www.youtube.com/watch?v=wJk2_drRo2s&feature=youtu.be&t=1m5s
PostPosted: May 13, 2015, 8:19 am
that's a really handsome car, Dave.
kewl that you're finding pics that other people have take. pretty sweet!
PostPosted: May 13, 2015, 8:22 am
Yeah it's kinda cool, although the videos are a bit more concerning. Have to make sure I'm not doing anything to stupid when leaving one of these.
