Got some work done on a few items this week. Rough mounted the diff, played with the tunnel a bit, and scored a pretty cool gas tank for not a lot of money.
The diff mounting went easier then I thought once I figured out where it needed to be. The driveline is the determining factor front to back, the hub height with 23" wheels determines the the height, and the outputs need to be centered in the frame so the 1/2 shafts are the same length. Luck has it that when it's in the right spot, the front mounts are pretty much directly over the lower tube of the rear bulkhead. That made mounting the front a breeze. A piece of 2x3 stock I had hanging around fit there nicely. It will get a brace or 2 to to keep me honest.
I started fabbing a rear mount for the diff when I looked over at the stock mount from the T-Bird the diff was removed from and realized I could use that instead. I hacked off the mounting tabs, welded it to a piece of square tube, and there it is. Cut a little plate for the back to close it in and keep it from twisting. Man, that was easy.
And here it is all level and in the correct (I hope) location.
I got a line on a custom 6 gal tank a guy had built for a drag racing car for pretty cheap. It's a nice tank with baffles inside and a bunch of inputs already in place. I scored it for $125 shipped, a price I'm happy with.
The dimensions are close to being perfect. Close being the operative word here. It's 10" from front to back and 5" deep. That would be great if they where switched, but there not, so I'll adapt.
I may still decide to turn move the filler neck to the side and turn the tank on edge. It would fit better that way, but that would mean welding on a perfectly good tank, so I will probably just leave it as is and build the rear around it.
I've been thinking about using the stock Kawasaki fuel pump for the car just like olrowdy01 did with Locouki (
http://dmr-architect.com/~locouki/fuel-pump.html ) . When I looked at the tank and the pump together however I got another idea. Why not just mount the whole thing on the bottom of the tank? It should fit nicely, and with the tank being flatish like it is, I have plenty of room to mount it high enough to work just fine. Hmmmm.
Lastly, I started playing with the tunnel a bit. I put the seat on the ground, piled some scrap wood around me and started figuring out the height of the tunnel. I came up with 8" above the base of the seat, or 9" from the floor. I then messed around with the width of said tunnel and decided 5" should suffice. Enough room for the drive shaft, diff yolk, carrier bearing, and drive shaft hoops. I roughed out one side of the structure and called it a day. The extra cross brace just above the diff is temporary. It's used to locate the long 3/4" tube at the correct height while building the tunnel around the nose of the diff.
Another reason to run the bike motor shifted to the left. Straight tunnel with lots of foot room for the driver! Passenger space? Well all they need to do there is hang on and smile.
Busy week ahead of me. Probably won't get much done for a couple weeks. As always, comments and suggestions are appreciated.
