Racepedals wrote:
I kind of expected it to be loud. I guess I was having a flash back to my 70's high school days when the extra noise was worth at least 50 more HP and impressed the tall blond girl with the long legs.
I do like the insert idea Toylocost mentions. Kind of reminds me of the Supertrap exhausts system for motorcycles. Remove plates and the sound changes. They offer these for automotive exhaust tips which is an option if they were not so expensive.
Could always build your own.
Take a pipe that is approx. 1/2 - 1/3 the diameter of your exhaust.. IE for a 3" exhaust, a 1-1.5" pipe.. find an old washing machine on craigslist, or the side of the road etc.. and cannibalize the drum. Cut the bottom off the drum, and down one side. Roll the drum out and flatten as you go with a deadblow. Trace the ID of your exhaust pipe onto the flattened washing machine drum/barrel. Cut out circles of the drum, and a smaller center section for the 1" pipe. Tack weld them 1" apart on the 1" pipe, and keep adding until you reach the desired level of baffle. Cheap, easy enough to do, and completely customizable to your sound needs. most washing machine barrels are made of stainless steel and have good heat resistant properties, so its something that will last, and won't hamper your performance any more than a cat would.
I plan on using no muffler, but baffling a 2-2.5 ft section of exhaust pipe this way, I think it will keep the look cleaner, and will still meet my states requirement of less than 92DB @ 50 feet.
Tucker
Driven5 wrote:
