It is currently December 12, 2018, 12:16 pm
Post new topic Reply to topic  [ 177 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12
PostPosted: December 11, 2015, 8:10 am
The rotaries also tend to melt cat converters. :shock:
I love the muffler cover. I'll have to remember that one, and possibility use stainless steel zipties instead of hose clamps. Then again clamps are easier to adjust as things squish and deform.
Walt
06 RX-8 Shinka
91 3000GT VR4
01 Tibb
04 RX-8 Touring RIP
PostPosted: December 30, 2015, 12:48 am
Finally I decided to tackle the roll bar. I wanted to make it removable so I have an option of doing a full cage later. Tubing is 1.75" 0.90 DOM. If I were to do a full cage, I would drop it down to 1.5" but for a single hoop design, the 1.75" seems just right.
File comment: I tilted the hoop slightly forward. Could have tilted it a little more for that Caterham look.
PostPosted: December 30, 2015, 9:28 am
Looking good Russell.
Will there be driving videos soon?
PostPosted: December 30, 2015, 5:48 pm
Wow Russ, you are really making some positive yardage on your build :cheers: . At this rate I hope to see some first drive videos come spring.Did you bend the roll bar yourself?
gavin
PostPosted: December 31, 2015, 12:37 am
Not sure about that drive anytime soon as I still have a lot of the small odds and ends to work on. But, the build is starting to inspire me more since it's starting to look like a car. I bent the bars myself so when you get to that point, I can help.
PostPosted: May 14, 2016, 1:26 pm
Well, been working on my gas tank. Not your typical rectangular tank due to the angles needed to have it fit nice and low in the car. I also wanted to reuse the Miata fuel pump assembly without modifications. I built in a few baffles so hopefully they will work out OK. Seemed to work pretty good with the open top water slosh test. Friend of mine machined the pump flange. I'm not the best aluminum welder but after pressure checking, I only had 3 leaks. I think it will be around 13 gals.
PostPosted: May 14, 2016, 6:31 pm
Looking good Russ!
28 years old, Welder and prior service (Army). Owner of 8Eight FAB (check me out on Instagram and Facebook @8EightFab). Currently building a square tube Car9 chassis, powered by a 2.3 duratec.
PostPosted: May 17, 2016, 4:32 pm
Wow, that looks great!
PostPosted: May 21, 2016, 4:08 pm
Looks good from my pint o' view...
PostPosted: May 21, 2016, 5:14 pm
Nice job on the fuel tank! Just a couple of observations from someone who worked on aluminum fuel oil tank trucks for two decades. I am assuming that the angles are going to be bolted to the frame in some fashion, and it is hard to tell, but it looks like the bottom (heel) of the angle is not welded. If I were doing my tank in aluminum (I am actually going to use Stainless), I would have put a shoe on the sides of the tank, welded all the way around. Then, weld the angle brackets to the shoe, making sure to weld the heel. As it is now, if you have any crater cracks, or any cracks start due to vibration or flexing, the two vertical welds are perfect candidates for a failure, since they are the primary welds holding the bracket to the tank. Should they fail, at best the tank will come loose. At worst, the crack will either propagate into the base metal of the tank, or allow the bracket to oilcan and crack the tank, either of which will result in fuel leaking. If you weld a shoe to the sides of the tank, and the brackets to the shoes, you have a much better chance of not dumping the fuel should something cause a bracket to fail. The bracket may crack, or even pull clean out, but it will not affect the tank directly. Other than that, the welds look good, and unlike many tanks I have seen done in aluminum, welded inside and out! Nice job!
PostPosted: May 22, 2016, 12:18 am
Lovely bends on your roll bar. How'd you do them? I mean, I know you probably used a bender, but if you could tell us brand and model (and what radius, and tell us what the tubing you used was) maybe we could all be that pretty.
Man, I love seeing pretty stuff on this site.
PostPosted: May 22, 2016, 8:40 pm
Thanks Dismantalus for the feedback. I completely agree with your recommendation. It makes sense and one can not be too careful with the fuel tank. I set the fuel tank in place and it sets low enough I should be able to fabricate a small aluminum trunk area under the deck lid.
Jack, roll bar is made using 1 3/4" x .120" DOM at 6" radius using a Pro Bender 105.
File comment: Tank sets low enough I will have some space for a small trunk under the deck lid cover.
