Been finally getting back to the locost build lately- have a couple more of the redesigned front suspension mount brackets fabricated. Going to work on a fixture to locate them a little better before tacking them in place.
I have also been working on the front lower control arms- have the inner tubes cut and the weld bung fitted, the outer rectangular tubes are fabricated and the weld fixture has been started. I plan to cut two slices in the end of each tube where the weld bungs fit to give some more weld area.
I ordered the front control arm pivot rod ends on Friday but learned on Monday that they are backordered until Christmas time. Plan B was McMaster Carr...these should be here this week but not as 'lowcost' as the QA1 parts..
I also moved the K3/K4 tubes out an inch per side so these line up with the A1/A2 tubes. I was never sure why these were inset the inch on the plans but with the IRS, this should be fine.
The N1/N2 tubes were fit and tacked in- these are not level but slope down an inch in the rear for some extra elbow room.
The M1/M2 tubes were cut and are just sitting there- probably will wait to finish welding the B1 to K3/K4 joints before installing the M1/M2 tubes when the time comes.
Feels good to keep fabricating new parts and not re-doing older work...
