So earlier I said I had finish my fuel tank...
Way back when ,,, I had planned on purchasing my tank. Thinking this would be simpler route. But my desire to use the factory fuel pump/ gage etc has pushed me to build my own. Now since I never intended on building my own tank, I had sold the one form my donor to a fellow who's tank has a leak. this turns out to be unfortunate as it contains the mounts for the pump and fuel vapor check valve. Now, I sold that tank a year ago, what are the odds of that fellow still having the old tank, but I thought it couldn't hurt to ask (ya see where this is going, eh). Sure enough, still had it and was only too happy to give it up for the cause (and get it out of his garage). Thanks Tyrone. I started w/ a cardboard mock up.
I choose cut out all the pieces rather than bending. Ya, a lot more welding, but I had picked up a new shear so thought I would be more accurate with the dimensions (this was not a job for the saws all). I'm very happy with how it turned out. Most importantly because it does not leak. I welded everything but the top panel inside and out.
This is a Miata tank cut in half if any one has ben laying a wake at night wondering. On the left you can see the bowl where the pump sits.
I decided to incorporate it in to my tank( tank also has a couple fo baffels).
For the fuel filler, again as I had not planned in building one I did not pull the fuel filler of the donor. So off the the wrecker and picked up 2 fillers for $10. ended up using the one from a civic ( the other was from a a PT cruiser).
And here is finished tank.
Tank volume is just about dead on 40 liters mathematically. I'm still undecide on coating the inside of the tank. Popped across the border last week to pick up some boots. More tire than I need, but options are limted in the 205/55R14's that I wanted in order to fill the fenders.
