In other news, found my next project. its a 1978 Honda Civic. These were my 1st 'winter' cars as a youngster. Found this (and the donor) sitting in a friends shop (Al). Al races and builds Hondas summer and winter. It had been disassembled and media blasted 8ish years ago, fully caged and then....sat (too many projects for Al).
So now its mine! Still bare metal. Not quite ready for it but couldn't pass it up.
The not so straight red car is an old ice racer to pick parts from (done).
And here is the proper donor. A 93 civic build for SMF. This car is a multiple class winner. Many FTDs. In other words, its fast.
Highlights-
Drivetrain:
-JDM d16a (SOHC VTEC- OBD1, identical to a d16z6 as far as I can tell)
-GT25R (ball bearing) turbo with a mix of ebay and custom plumbing, intercooler, etc.
-internal wastegate - 8 psi
-Precision injectors, Walbro fuel pump, AEM wideband, tuned with Crome, runs on 91 octane
-Upgraded but totally streetable clutch
-MFactory helical diff
-Si transmission with 4.06 final drive in place of stock 4.25. 2nd gear at 7400 rpm is ~105 kph.
Suspension:
-Koni SPSS (shortened and race valved) with adjustable perches and 2.5" coilover springs
-Integra front sway bar
-ASR 24 mm rear sway bar and brace
-adjustable front and rear camber
Other:
-Integra steering rack (powered)
-carbon fiber hood with hood pins
-fenders rolled/beaten/pulled for big tires
-Si gauge cluster
-Sparco seat on drivers side.
-ARP extended wheel studs and solid aluminum spacers
Again not ready for it but. couldn't pass it up. I had initially planned on just using the drive line but may see if I can work the suspension into the 78!
And as a bonus, until I part it out I'l have a rain car for AutoX!
