Time for an update...
Life is starting to settle down, so I got the chance to get back working on my car.
First order of business was the installation of the 3 gallon fuel cell... Since the car is only going to see Time Attack and some Solo 2 Duty, no need to have a 10 gallon tank... 3 gallon is more than enough for 15-20 minutes sprints.
The idea was to place it in order to offset my weight in the drivers seat.
Nesxt order of business was finishing the rear end. The original plan was to make that piece as a single piece, but this is a race car and since I will need to go fiddle in there on a regular basis I decided to mae the center section removable.
I have plenty of access to the fuel cell battery, fuel pump, mumford link and shocks.
Next order of business was taking care of the tubs side. That was fun with all the cage anchor points and Dzus tabs there were lots of cut-outs
I had mention a while back about getting the Pinto spindle to work with the 13inch wheels. The Diamonds didn't work out and the best back space we could get up front with our big, overkill for a Se7en 10.25 vented brakes was 2.5 inch of backspace. I while back I reconsider the braking set-up as this car will never weight 2000lbs. I decided to change my DynoPro Caliper for some Powerlite calipers. The Powerlite is a smaller than the Dynapro, plus I'm downsizing to a 9.5 inch solid drilled disc, some clearance will no longer be an issue.
With the +4 offset the 13X8 are close to 4 inch backspace i.e. tad more. They do not clear the Dynapro/10.25 vented disc combination. Also as the slick moves around I'm not too sure about the top of the rod end/ bolt... my little Go Pro cam will need to have a close look at this.
Now with a 0.5 inch spacer this are interesting. I am now clearing the Dynapro caliper with the 10.25 inch disc... OK it's really tight and I'm not too comfortable with the clearance I need to measure it but it's probably between 1/16 and 1/8. Theres plenty of space for the slick to move around and we have more than 3.5 inch of backspace
Fred
