So, the question is, how do you build it stout enough to survive that kind of beating.
You don't. Plain and simple. You cannot build to sustain a rear end crash at, say, 30MPH. I am talking from experience. I have been rear ended more times than I can count on with one hand and am almost to the point of needing to count on my toes. There is no space available in a Seven for a crush zone. and the car is 1/2 to 1/3 the weight of your normal sedan, which means your car will absorb 2x-3x the impact force that the other car will.
I'm also toying with the idea of using a home made tank made of 12 gauge steel on the theory that it would be one tough mother to break open.
Consider that if you make a strong tank, then that tank will be slammed into your back. If you let the tank deform, but maintain its contents, then I think you are better off. I think that the idea of a "real" fuel cell is good. Bladder and foam. Figure close to a $1000 for a custom bladder and design to racing requirements. It should hold together better in a crash than the welded up tank that "Uncle Ron" designed and safer than your ~1/8in steel armor. That being said, here I am welding up my second fuel tank. Go figure!
Keeping things safe is a good goal. Anything done to get closer to that is a good step forward. But, it will never be anything approaching SAFE. It "may" be generally safer than a motorcycle though!
If ultimate safety is your goal, look into buying a 2013 Whatever. If fun driving is what you seek, build a Locost.
Sorry if this seems to be a rant. I can't word it any other way without sounding this way.
