Thanks, guys for the feed back. Today I’ll cover the power train.
The motor was from the beetle. It’s nothing extreme a 1915CC with 94 mm cylinders. The heads are 44 casting with larger valves. The cam is an Engle W120 cam is hot street cam. The carbs are Webber Dual 44 IDF’s with CB performance linkage. I had a Bosch 009 distributor but converted it over to CB Performance Digital programmable ignition last week. The motor was purchased as a turnkey and was rated at 120 HP. Future plans is to replace the heads with a CNC ported pair from CB performance and replace the jugs at the same time. But that’s later on.
The bell housing is from a VW bus. Since on the Type 1 transaxle the bell housing is part of the casting I needed to source another option. I picked up a Bus transmission off craigslist cheep, stole the bell housing and resold the trans. Inside the bell housing lives the clutch and flywheel. The fly wheel is a 12lbs machined forged with a Kennedy clutch disc and 1700 pound pressure plate. Also a high torque starter has been added. The 924 bell housing would not work for a couple of reasons. First it the engines in a 924 is tilted and second the bell housing bolt pattern does not match. The last item with the bell housing was making an adapter plate to bolt the torque tube to the bell housing. This ended up being rather simple since the both surface where flat. I only needed to match the depth of the vw type 1 transaxle input shaft to the input shaft of the torque tube. The distance needed to space the torque tube if I recall around .900 inches so a quick mill of a one inch piece of aluminum worked perfectly.
The torque tube and transaxle are 924 components. I have an early 924 4 speed with a tall second gear and also a 5speed version. Currently I installed the 4 speed since my plan is to autocross the car locally the first year and sort some thing out and next winter start making it road legal. The only other modification I did to this assembly was shorten the shift linkage bar about 10 inches and remount the shifter to a location that was more Locost 7 friendly.
Chris White
Locost 7 type 1 power and a rear transaxle
Lotus Elise Sold
ND Club Miata
Nissan Titan Sold
Rubi Wrangler
http://www.locostusa.com/forums/viewtopic.php?f=35&t=13200
