Wheezer wrote:
Jack,
The tubing is actually 1x1.5"x16g HREW (assume 40-ksi yield strength). Using your numbers I come up with roughly 32-ksi stress at the top/bottom of the tube at the flange (been a while since I did any real analysis) - this does not take into account the added cross sectional area of the vertical tubes, just the top/bottom sections, as I know the stress goes to zero as you near the center of those sections. But I'm assuming the force is actually higher than what you listed since it's only 1.5" tall tubing, and not 2".
If you don't mind, could you run that calculation again for 1x1.5" tubing, assuming the length of the motor mount is about 9.5" from the mounting flange to the center of the pivot on the urethane motor mount, and the angle from horizontal is about 20-deg. Also, assume the motor is a bit warmed over, maybe something in the range of 200-brake hp, and 150-lbft tq.
Just wondering if I should add gussets or maybe re-make the mounts using thicker gage tubing. I know eventually I'll have more power and sticky tires, and although I don't tend to do burnouts, I don't always exercise a great deal of mechanical empathy. I was just looking at some pics of a duratec powered CSR and noticed the engine mounts have a much taller cross section at the motor flange than caterham's old style mounts did.
John,
Using the numbers you provided, I come up with 27ksi stress at the tube to flange junction. The numbers I used for this is your 1x1.5x16g tube, 9.5" long from flange to center of bushing, 150 lb-ft motor torque, 3.16:1 first gear ratio, 250 lbs for the combined weight of the engine/transmission that is sitting on the 2 front engine mounts (I'd assumed most of the trany weight is on the trany mount), and 26" center to center between your 2 front motor mount bushings (I tried to error on the short side since this is worse but won't make a huge difference). I did not factor in the 20 degrees since at this angle it has a small effect since we should be shooting for a good factor of safety.
I ended up with mount loads of 334 lbs down on one side and 94 lbs up on the opposite side. This does not take into account any shock loads or loads from inertia from the vehicle moving.
I think the 27ksi is high. I typically use 35ksi for yeild on mild steel tubing, so this doesn't leave a great FoS.
Going to 1x2x16g tubing would reduce this stress to 17ksi. I would consider this to be marginally acceptable, but if it were me, I'd go for a FoS of 3 or better. The weight penalty is small compared to the consequences of the motor mount failing IMO.
Going to 1x1.5x11g would be marginally better than 1x2x16g at 15.4ksi.
Going to 1x2x11g would reduce the stress to 9.9ksi.
Going to 2x2x16g tubing would reduce this stress to 10.5ksi.
Going to 1x3x16g tubing would reduce the stress to 8.9ksi.
Going to 1x2.5x14g (didn't find this size in 16g) would reduce the stress to 9.5ksi.
Going to 2x2x11g would reduce the stress to 5.9ksi.
Alternatively, if you want to be creative (and I know you do!), you could make this a tapered tube by cutting 2 tubes on a diagonal length wise and welding them together as a taperred tube. You could then go as tall as your motor flange will allow (leaving room for the fillet weld) and tapering down to your 1.5" at your bushing.
Hope this helps.
Jack
