After going back and forth on the build-or-buy question for the nose, I finally decided to try my hand at building one. While I like the Kinetic nose, with the exchange rate between USD and CAD as well as shippng from the states, I thought it would be worth it to at least give it a go.
First I made a wireframe buck from some 3/16" steel rod bent up by hand. I tried my best to get it symmetrical though I'm sure it's far from perfect.
Next I skinned the frame using poster paper. Each of the panels was cut such that only a single curve was required for each section, which meant that in theory I could reproduce that in metal. However, that would require welding the individual panels together, and I don't have any good means for welding thin aluminum. Plus there would be some sharp transitions that I don't like.
The logical thing then is to use this as a buck for a fiberglass part. The next step is to add some thickness to it so that I can sand it down to the final shape and smooth it out. I decided to try doing this with paper mache as the base to give some rigidity, and then some sort of plaster of foam as the filler. I did the first paper mache layer last night, although I forgot to snap a picture. In hindsight I should have coated it with clingwrap or something before addind the wet newspaper, as the moisture caused the panels to sag. Interestingly, the poster paper panels that had the picture side out (instead of the white side out) absorbed a lot less water and were mostly unaffected. I didn't know that the ink they used is so waterproof.
