After searching around I found this
viewtopic.php?f=23&t=8225 which is along the lines that I am thinking, lower the frame to cover the oilpan... I didn't see any real evidence one way or the other and don't know what nether10 decided on. I think that if I design the car with a 3.5 inch ride height it should work which is close to what someone recomended on that thread(being 4 inches).... with the pushrod suspension I also have the ability to adjust ride height easily by using a turnbuckle type adjustable pushrod...
Just thinking out loud....
I guess I don't know about the pushrod suspension and that ride height, with 800lb springs and a 2:1 ratio, that would be a wheel rate of 200lb... Maybe more if I could design a rising rate system. Also with 2 2/3 inch bump travel that would leave me with the bottom of the car 1 1/3 inches off the ground... I guess Its no different if the whole car is that close vs. just the oilpan, both don't seem to great
Just looking for your opinions. could go with a smaller ratio which would up the wheel rate but give less travel.... man oh man decision decisions, I think I should get the motor out and see what it looks like in the frame.
p.s. thanks for the comments on solid mounting, I didn't take into effect durability issues with fasters loosening I seem to recall some miata people are able to minimize vibration by upping the idle to 1k vs 800.... But more than likeliy I'll start out with some stock miata mounts and work from there!
p.p.s. could always run a rod from the frame to somewhere higher up on the engine to minimize side to side movement but still allowing vibration dampening
