I'm moving along diligently with Kate...I should have both the steering and brakes totally completed and operational by next week. The fuel cell is here and "on deck" along with the Miata wiring harness (I'm still avoiding cutting wires even when it's all laid out and ready for me!) I lost 5 days around New Year's due to a stomach virus and I'm still going to be close on getting it running by the end of the month. At worst it'll be February. (NOTE: Thanks to my buddy Tom and to Jack @ Kinetic Vehicles for all their recent help and assistance!!!)
With the 6" extension of the cockpit to accommodate my height, I determined I needed to extend the gearshift lever. I bought a second Miata lever for $15, heated the rubber isolator under the lever with a torch and pulled off the top piece. I made a couple 45 degree cuts on a piece of tubing and found an appropriate size bolt for the gearshift knob.
Tom welded it together and while it doesn't fall into the "really pretty" category, the prototype fits and feels really good! !
I also bought a new boot/dust seal and rebuild kit to take all the
sloop out of the gearshift lever.
Brakes: New rotors and EBC Greenstuff pads were installed the first week I got Kate back in October. Today I laid out all the brake components and am ready to start laying out the line.
The more I read and researched what to use for brake lines & fittings the more confused I got! After driving myself nuts trying to figure out which direction to take (-3AN versus inverted flares, metric or standard fittings, conversion fittings, composition of brake lines, etc. etc.), Tom came over and said, "It's easy!" So again with his help, I'm using what he and Bob used...industrial grade stainless steel lines with mostly 1/8" NPT fittings. The trick was to convert from the Miata calipers to 1/8" NPT fittings, so...I found four Russell 10mm to male -3AN banjo fittings (at Summit, Jegs & Motorcycle Superstore) and will use the original banjo bolts from the Miata banjo fittings. Then I'm using four of Earl's 24" braided stainless steel hoses with female -3AN fittings on either end along with -3AN male to 1/8" NPT conversion fittings to attach the braided hoses to the hard lines. (My three Wilwood master cylinders use 1/8" NPT fittings.)
Bada bing!A few final tig welds on the steering column & u-joints and I'll be able to sit in the car, turn the steering wheel and have the front wheels turn...
that's magic!!!
