GonzoRacer wrote:
OMG I have a lot of work to do
Yep, know that feeling... The thing to do is stop and think it through. A lot... If your first thought is "take off the front subframe" for example, then your second one should be, "and how will I move this thing around the garage then"? Or something like that. Your car may already be on dollies or not need to move, I dunno. Anyway, point is, don't let the apparent enormity of it all spur you into rushing. Plan it out and avoid that "Oh Sh*t!" moment...
Am I preaching to the choir? If so, sorry.... Tryin' to help...
JD
Yeah I have been thinking about moving the car. I do need to move it and currently have 2 options. either put wheels on it and jack up the front and push it, followed by the rear etc until it is in position or get to harbor freight and buy 2 dollies which will allow me to move it whenever I need to. I think I will go with the dollies. Especially as I only have 4 jack stands and they are all currently on the supra.
As for the seat I will be getting the Kirkey budget seat, I want to mount it on rails I think I will use the passenger seat rails from the supra (if they fit the seat) I will probably use the bolts and then stitch weld the rails to the floor. Who knows that too far in the future for me to worry about I need to concentrate on the task at hand.
Current problems are what to do about the rear end, I have 3 options.
1. Use the supra sub-frame - easiest, fastest, cheapest heaviest
2. Use the uprights and suspension control arms (fab my own lighter sub-frame incorporated into the Locost frame)
3. Just use the uprights and fab everything - Hardest, lightest
I think I like the idea of the 2nd option I can actually remove the bolt mounting points and weld them up to the frame of my own design to allow all the stock adjustments of the Supra. My Miata coilovers will fit the suspension with a couple of washers installed which should work out pretty good.
Scrap Metal Build Log
viewtopic.php?f=35&t=14558
