Trochu wrote:
That almost sounds like cheating Tom?!?
Probably true, but I'm a bit adverse to screwing up big ticket items until at least the credit card bill has been paid off.
Lonnie-S wrote:
Drive by Wire throttle? Sounds cool. I'll be interested in what that looks like. I'm assuming you'll have a gas pedal with stuff built into it as a sender.
That's pretty much it, Lonnie. Here's the long story: The GM crate engines have an "optional" ecu/harness kit.
The kit includes the ecu programed for the specific engine, the engine harness with fuse/relay box, sensors and the throttle pedal assembly.
The throttle pedal assembly is quite long with the stock pedal, so some shortening is in order, as is some creative mounting. Lokar makes a nice replacement pedal that that shortens the assembly considerably. But here's where the sensor needs to fit to avoid that diagonal tube
And the pedal really needs to be positioned to the right about 1.5"
So I'll need to make an offset pedal-to-sensor-lever mount that locates the pedal where it needs to be while accommodating the sensor mounting arrangement.
Briggs wrote:
He should be able to use any Chevy (that has an LS engine) pedal that is drive by wire.
Turns out GM has a family of these pedal assemblies. Different ones for different motors. And Lokar makes a family of nice replacement sensor/pedal assemblies that are very specific as to their use. So not sure that one size fits all LS motors without additional tweaking.
BTW, one of the classic drawbacks to drive-by-wire throttles has been throttle lag. Turns out lag is programmed in by the factory and can be tuned out by tweaking the ecu. (Lokar sez they do it by tweaking the sensor in their product.) I'm also hoping that the idle to WOT ramp curve can be customized in the ecu. 15 degrees of lever movement isn't a lot when you are driving in traffic and don't need/want WOT to creep ahead
