bob wrote:
Its all getting very busy on and around that top joint, as you have adjustability on the top wishbone inner rod end it may pay to include one of these joints below on the outer and fabricate the bracket for the top of the four link off of it.
Bob, thanks for stopping by and your thoughts on using spherical bearings, that area does get busy and has been the subject of a lot of offline discussion. Current plan is to use a 1/2" x 5/8" rod end with Hennessey Hats in that upper "bushing" hole as Horizonjob mentioned (also in the lower front hole) and a Whitby spherical bearing kit in the lower rear "bushing" hole which carries the spring load.
Tom are the bearings in the Whitby kit easily replaceable? I'm trying to remember if they are held in with a snap ring. If they are held by a snap ring I wonder if they move back and forth because it seems you would nee a little clearance to install the snap ring...
Marcus, as I understand it, the spherical bearing is positioned by shouldered finger sleeves on each side which are then held in place by the U bracket. A 14M bolt goes through all of this clamps it all together. Shouldn't be any wiggle and easily replaced. O-rings hold the pieces together until fit into the U bracket. A snap ring helps hold the outer sleeve. I have a pair of the Whitby kits on order and will post photos of them when in hand. In the meantime, here's Whitby's website
http://www.whitbymotorsports.com/UInvDe ... oryid=1610 with more info in their instruction manual
http://www.whitbymotorsports.com/upload/irskit.pub I believe the kit was originally built for the FFR Cobra IRS set up.
JustDreamin wrote:
Also, there are different kinds of taps. The standard hand tap typically has 4 flutes. My personal preference is to use spiral point taps for most every application. They're really only recommended for through holes, not blind holes, because they push the chip forward, but they cut much easier and are stronger since they typically only have 2 flutes (less material cut away). But they're more expensive, and have more limited availability. And don't confuse spiral point (also called gun taps) with spiral taps and some of the other specials out there.
JustDreamin and CheapRacer, thanks for the education on taps and their use. I was just about ready to head out and buy a tap to clean-up some threads that have a little heat distortion. I'll be a lot smarter now.
