Here's an update on your model. We're not done but I did some cleanups and filled in some details. I probably don't remember everything. As always you can change some things back the way you had them because I may not realize what you are doing. Some things are easy to change other things may be something the car depends on to be strong or stiff.
Here's a quick list of changes.
- put the side of the frame into a component and then copied and flipped it for the other side, now they should be identical
- made the car 44" wide. We can change that and I should double check to make sure it's centered
- added a couple of dimensions.
- fixed some tubes, how they were rotated. Try to rotate the tubes without opening them up. Just select the move feature and use the little "+" symbols that appear on the face of the object.
- filled in some engine bay bracing on the top
- put in some 1"x2" tube on the floor. Most of that is needed for strength and stiffness. 1"x2" tube is about 8 times stiffer in the 2" direction, so that is why I use it across the floor and under the dash and main hoop.
- started some work on the rear bulkhead inside the main hoop. You can see how the idea is to tie in to the place that the diagonal and shoulder bar intersect. Oh we may need the shoulder bar at a different height for the seat belts.
Take a look and let's make a list of things to do...
https://3dwarehouse.sketchup.com/model.html?id=u5b0b01e5-50e5-405e-9c38-35d35a23d39e
