Lonnie-S wrote:
I figure that black rubber stuff would be useful as a friction layer on top to prevent slipping.
That's exactly what I figured, something like a floor mat, easy clean up, maybe a sound dampener, and a non-slip surface...for some reason I see myself climbing into it on a rainy/humid day (like we ever have those in Arizona) and I slip on the slick steel surface and biff my face on the windshield or get the shifter in my @$$....just a phobia I suppose. I checked it before going to work this morning, it's dry to the touch and feels just like molded/fitted floor mat. I'm going to go home and do a sneaker test (get in with sneakers and do the "twist" dance to see how well it holds up)...very scientific and should not be done by amateurs
It did end up having a slight texture to the finished result, I'll try to get it on film and upload it tonight. If it doesn't go well then I'm out $14 plus some sand paper...oh well.
Trying to figure out what to work on tonight...something I've got all the tools and material for....hmm.
Looks like I can work on:
1. Mounting and connecting the coolant reservoir
2. Double check all the nuts and bolts for the front suspension
3. Install front brake pad kit (some springs were wore out, just need to put the new ones on)
4. Clean up the exhaust manifold a bit before getting the new pieces
5. Work some more on the emergency brake mount and cabling.
6. Wrap up and hide more of the wiring harness
7. Mount the diagnostic box, Bias adjustment cable, etc.
Well, at least I have something to work on...
