Been awhile since I updated my log. Its been cold out in the shop and I have been spending a lot of time with my daughter. My wife went out of town to go wedding dress shopping with her sister who is getting married in 2015 and the weather warmed up enough to go out to the shop. It was nice to get out and mess around on the car.
Finish tacking up most of the triangulation on the sides, still need to add the additional bracing at the very front.
Test fitted the engine for the first time. I havent removed the frame from the table yet so the engine is sitting ~1.5" higher than it will in its final resting place. Looks like the slave cylinder might determine the final location as it will hit one of the lower frame rails if I drop it much more than 1.5". I also have only about 1" more I can move it back before the slave will hit the frame at full extension. My research shows the slave has 5/8" stroke. I may get my wife in my red miata and measure the stroke on it to comfirm.
I also started on the rear tubing and test fitted the diff for the first time. I need to do some more measuring and test fitting to get a final location. I want the tunnel to be as narrow as possible, but it looks like the flange may force the passenger side of the tunnel out a bit. This will either require a wider tunnel or flaring the tunnel where it meets the firewall. Also, I need to verify the vertical location of the RA56 Tubes as the diff flange is very close to the bottom tube of the firewall and it is still sitting higher than the final position according to the plans.
One change I did make vs the plans is where RA5 meets the firewall. This has always concerned me in regards to rear impact protection. With RA5 pointed right at the passenger's back I wanted to provide more protection. I cut the tube short and fitted a 2"x3" x 3/16" plate to spread the load. These will be fully welded to RA5 and the firewall tube.
