horizenjob wrote:
Here's what my diff support legs are looking like right now. I'm showing the drawing because I may have worked myself into a corner. When I went to the salvage yard I bought an Explorer diff because I thought they would be more available and they come with the rear cover I wanted to use. I suspect they have a lot more aluminum in the casing though. tHings like large reinforcement ribs for the pinion bearing. So I think it sits higher above my cross tube at the back of the floor, which I raised a few inches.
Long story short I am trying to decide now wether to cut out the cross tube currently in te car, which I already notched down 1" in the center or simply cut out the middle few inches and thing of a way to reinforce it.
At the moment my diff sits nearly 2" above where Tom has installed his in his car. His car has 2" or 2.5" more ground clearance but he is likely using taller tires.
So that's my problem and here is the rest of something like an explanation. Tom's car has a main roll oop that goes all the way to the bottom rail. On mine It only goes to the top rail. I don't see either way as preferable yet, what I did probably gives an inch or two more cockpit room, but I'm 6" shorter than Tom, go figure...
On this car the cross tube for the grasshopper legs is moved forward to the bottom of the roll hoop. Instead of a sleeve to capture the bolt mounting the rear diff cover, I am using a length of flat bar. I built the sleeves, but when I was holding them in place i was concerned about what would happen to the fuel tank if the car suddenly got 6" shorter in the rear. The bar stock will have another hole below the diff mount to bolt strap for supporting the fuel tank. It will also allow adjusting the height of the diff - so this car is more of a working prototype than Tom's is. The diff height will be adjustable to help with playing with aero under the car.
Marcus, your cricket legs look like an efficient alternative. Have you thought about triangulating the diff mount points out towards the roll hoop - top rail nodes?
To make things fit, it may be possible to cut away some of the Explorer diff case webs instead of the chassis.
My solution to the fuel tank “foreshortening” problem will be a race spec bladder. Not fond of the flambé notion. My tank will hang, in part, from the 1” square tube between the shock mount points.
Lots of room for creative alternatives aft of the roll hoop.
