It is currently June 4, 2020, 4:53 am
Post new topic Reply to topic  [ 673 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24, 25, 26 ... 45  Next
PostPosted: February 4, 2017, 12:14 pm
Any chance you could pop the bushings out and turn them around?
PostPosted: February 4, 2017, 12:51 pm
I think you are fine as you are. Caster? You don't have rear steer. Shouldn't be an issue IMO.
PostPosted: February 4, 2017, 8:46 pm
Well today is a day for problems or maybe solutions :BH:
As i was figuring out how to make the ebrake work, i noticed that the way i mounted the shock in the rear would place rotational torque (redundant?) on the spindle mount. The way i figure it, at full bump, the shock would produce ~1500lbs of force from the spring (468 x 3.3"). even though the rod end is only 1" from center, that translates to almost 170lbs of torque through the spindle mounting bolt.
Originally, I thought i would mount the shock at the intersection of all the tubes thinking that it would be plenty strong. I changed it mid-stream because i wanted to improve my wheel rate and I thought it would be better to put the load directly on the spindle. This would then prevent putting the 5/8"-18 bolt that connects the br@ck&t to the lower control arm in bending. But since there is less than 1/2" of thread out of the LCA and the bolt is rated to 27000 lbs in shear, I hope i will be okay if i place the shock back where i originally planned to.
By changing all of this, i might be able to put the brakes back where they are "supposed" to go.
File comment: The red circle indicates where i plan to place the lower shock mount
Gavin
PostPosted: February 5, 2017, 9:27 am
Yo Mnot-
I think that proposed mounting point will work OK. There will be a decrease in effective wheel rate as you noted. On the Slotus, I have a very similar LCA and have the coilovers mounted on the rear-ward intersection of the tubes much as you're showing. No problems, works just fine...
I can't comment on the e-brake situation. The Slotus ain't got ner'n...
Been trying to get the damn thing to roll away, but it won't leave!!! :twisted:
Found a blurry picture that almost shows how the coilover is located. I'm lookin' for a better shot... But you get the idea...
PostPosted: February 5, 2017, 7:26 pm
Damn Gavin, I never thought of mounting the brakes on the spindles. Idk why I assumed they were on the front of the spindle.
PostPosted: February 12, 2017, 8:22 pm
I think i figured out a really good solution, it involves the sawz-all. I will share pics soon
Gavin
PostPosted: February 13, 2017, 2:35 am
Almost as bad as a grinder, almost.
PostPosted: February 13, 2017, 8:43 pm
oh, it involves one of those too but i didn't want to scare you :twisted:
Gavin
PostPosted: February 13, 2017, 10:24 pm
Well, all I can say is, I'm glad I am not the only one that had to break out the Nuclear Option this week! :ack: Looks like I'm in good company!
PostPosted: February 14, 2017, 12:24 am
What are y'all talking about??? I thought EVERY project involved a grinder?!?!? :shock:
Well, every project above making a peanut butter and banana sandwich... :mrgreen:
PostPosted: February 23, 2017, 9:00 pm
So I have created two options for the lower rear shock mount. It is constructed of 1x.120 wall tube supported by 3/4"x1/5"x.083" rectangle tube that has a hole drilled to receive the 1" tube and welded everywhere i could fit my welder
1. Uses bronze bushings for pivot
File comment: Lower rear shock mount with poly bushes
2. Uses universal poly bushes massaged to size (narrowed). This would be welded directly to the LCA with a gusset toward the inside for strength.
File comment: Lower rear shock mount with bronze bushes
My concern with option 1 is that there is no room for lateral movement so if i am just 1* off it will destroy the bushings in no time. Option 2 is more forgiving.
I would really like feedback on this.
Gavin
PostPosted: February 24, 2017, 12:02 am
I'd go with option 2 because, as you said, it's more forgiving. You know something is gonna warp or slip or just generally move that teeny bit that'll eat up your bushings... Hate to be a pessimist, but, you know Murphy's Law as good as I do...
So, go for the forgiveness! (Sounds like a sermon title... Hmmm... "Brothers and Sistahs! You got to go for the forgiveness!!!"...) :mrgreen:
The Reverend JD
PostPosted: February 24, 2017, 7:41 pm
I guess Amen brother! is appropriate??
Gavin
PostPosted: February 25, 2017, 12:09 am
Good answer! Now hang around until we pass the plate! :mrgreen:
PostPosted: February 26, 2017, 9:16 am
I have had a pretty productive weekend. The rear shock mounting is complete. I need to clean things up, from the setup i cut out, before welding in the new setup.The upper shock mount is notched slightly to keep all of the centers in alignment which, i hope, will make it stronger.
Gavin
