Tundra 7 wrote:
So the travel value and droop is garbage that Brunton was giving me? I just read a Hypercoil article on springs and shocks that said 45-50% of the shaft length you want set at ride height. That is huge. Dennis said you only want 1" droop. Unless I have this all wrong with a shock set at ride height with a 6' travel you will have 3" compression and 3" rebound. I have 12" C-C on the mounts so a 12" shock set at 50% droop sets the piston in the middle of the travel. Dennis told me go with a 4.5" travel shock and 1" droop. Guidance Please!. Now I know he raced a lot and a good handling car is what you want but i need to keep the fillings in my teeth too.
The typical standard for shocks is 2/3 in compression and 1/3 in extension (droop). The reality is you need just enough droop to keep your unloaded wheel on the ground when cornering and enough compression to make sure you do not bottom out the shock on full load or bumps (you can also use bump stops) if you don't have a lot of travel.
I doubt you will get 6" of travel on your shocks. With my push rod suspension I have about 1.2: motion ratio (more shock than wheel movement) and I only get about 2" of compression, maybe 3" of total travel. Traditionally mounted shocks with about 0.7:1 MR only get about 2" of total travel.
Scrap Metal Build Log
viewtopic.php?f=35&t=14558
