It is currently May 21, 2019, 4:37 am
Post new topic Reply to topic  [ 753 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 51  Next
 Post subject: Re: Tundra 7 442
PostPosted: February 28, 2015, 8:48 am
Driven5 wrote:
How thick is the strap of sheet/plate that the trailing arms bolt to on the chassis?
Hi, Its 2x1/4"
Steve
PostPosted: February 28, 2015, 8:52 am
Acerguy wrote:
Welcome to another Wisconsiner! I'm definitely planning on going to the Midwest 7s Gathering this year. Here is the LINK. Hope to see you there. Also, you can see what they did last year at the Midwest 7s Gathering.
Looks like you are making great progress. :cheers:
Keith, Very nice I was wondering if their were any other wisconsonites on here. I am going to try to make it to the 7 rally. I need to ride in one of these things!!
Steve
PostPosted: February 28, 2015, 9:01 am
egoman wrote:
Nice to see another UA hand making use of the skills we learn on the job to entertain the masses.
Shawn Wedge Instructor Local 254 Winnipeg Mb.
Don't give them too much to look at in one day, these guys wont leave you alone.
Hey Shawn, Nice to meet you. Thanks for the advise. Things will slow down for me too here in a couple months. You know how winters are. You'll do anything to fill the time.
Steve
PostPosted: February 28, 2015, 9:03 am
locofinn wrote:
Nice looking welds. :cheers:
Thanks, Love the car building quote on tasks. Add in 14hrs of research to that too.
Steve
PostPosted: February 28, 2015, 9:06 am
I just saw the dates, Those two weekends are booked. I may be able to get down their for the day The 29th. I'am going to see if I can work that out.
Steve
PostPosted: February 28, 2015, 10:10 am
viewtopic.php?f=36&t=7995
Here is something for you to look at when it gets slow and cold out there.
PostPosted: February 28, 2015, 11:14 am
http://www.fendersnmore.com/
I've used these on 2 cars so far and will use them again and again.
Another great build :cheers:
PostPosted: February 28, 2015, 11:18 am
Beautiful welds? Specs? AWS? I will need to see your WPS.
I worked in the field once and met a welder who said he didn't know what a WPS was. I told him it meant Whoops and every time he finished a weld and wanted the inspector to approve it, the welder had to yell out "WHOOPS!" as loud as he could and the inspector would come a-running to sign off on the weld. I quickly left the jobsite after that.
PostPosted: March 1, 2015, 4:05 pm
Tundra 7 wrote:
Hi, Its 2x1/4"
Consider your engine making 115 ft-lb of torque at the crank, with a 3.136 first gear, and a 3.27 rear end. That's ~1180 ft-lb of torque at the rear axle. Since our at least lightly modified installations usually net a little power over factory, let's call it an even 1200 ft-lb. That means each of those straps is reacting against up to 600 ft-lb of torque. It may be fine, but considering the section properties of flat stock, it doesn't exactly inspire me personally with a lot of confidence either...Just some food for thought.
PostPosted: March 1, 2015, 6:38 pm
Just another thing to consider, it may be fine as is, but I'd also want the connection on the axle in double shear. Would be really easy to do with just another braccket similar to the ones youve already built.
Trochu Motor League
PostPosted: March 1, 2015, 7:14 pm
Single shear of a 5/8" bolt isn't enough? Plus a total of 2.5" of 1/4" fillet on both sides of that 3/8"bracket. I think it's got some beef.
Steve
PostPosted: March 1, 2015, 7:48 pm
I wouldn't be concerned about it physically shearing off, more the possible bending and movement associated with repeated "launches" which would lead to failure. Others would be able to offer better advice than I, just my $0.02.
Trochu Motor League
PostPosted: March 1, 2015, 7:50 pm
Today was productive. Very nice to see this done except coil overs. From my head to in garage. Sometimes not an easy thing.
File comment: I have to add gussets top and bottom of the round stand off and tap the hole for for the counter rotate (small hole in plate)
File comment: Now the 4 bar is permanent.
File comment: Panhard going in
Steve
PostPosted: March 1, 2015, 9:39 pm
I picked up 4 scales this weekend and weighed the car as is 600# exactly (ouch). shooting for 1200# this will have to be policed.
:BH:
Steve
PostPosted: March 8, 2015, 2:49 pm
Its killing me to not work on the car this weekend. I have front rotors on order and i have to pick up square tube for bracketry, .095DOM for bushing sleeves. next week is spring break in Florida where winter dosen't exist thank God, I am so sick of it. It will be a couple weeks before the wishbones get laid out.
:ack:
Steve
