mgarc1973 wrote:
Hey Josh,
I am a self taught welder, but still have a lot to learn when it comes to tig!! That weave pass that I was practicing on was done with the little Miller Dynasty 280 that we have at work and I swear that rig will make anyone look like they know how to weld, it is by far the best rig I have used to date. On my chassis I did use MIG here and there for suspension pickups and other odds and ends, but all of the chassis tubes and control arms are all TIG.
Would you switch the whole rear end out for a torsen, or just replace the guts and put in a limited slip diff and up-rated ring and pinion? I know swapping to a torsen unit with half-shafts, drive-shaft, and diff assembly is kind of ridiculously expensive. I have actually been looking at that ISIS rebuilt T25, or a TD04 off of a Subaru mainly because they are a great size turbo for the 1.6 and you're not paying $1400 for a Garrett ball bearing turbo, which is the only thing the pre-done kits seem to come with. As far as the manifold I was going to do exactly what you said and get SS weld fittings and I have found a DXF file that someone made for a 1.6 flange that I will have either laser cut or cut out on the water jet at work.
On a side note my brother and I were looking into buying a racing kart just to toy around with at some of our local "track", more like parking lots, but what could you tell me about what to look for in a simple, entry level racing kart? I was trying to just find a chassis and then add a little 6.5 hp clone engine to it so we can get into it and then work up to a full blown shifter, Rotax, or whatever style kart we could find to race locally.
Thanks
Even the aftermarket diff's for the 1.6 are not much better then the torson. If it were me I'd mock up the car with what you have and keep an eye out for a good deal on a torson.
I'm actually selling my shifter kart. It's a 2012 Gallard chassis with a built cr125. Part of me wants to keep the frame and just sell the engine.
You can get a nice frame for around a grand. Birel, CRG, Tony kart.. All good frames. Many more out there but those are the big ones.
