More work on detail items like where to put the air filter and under hood organization. Nothing too exciting but it all needs to be organized in the end. Currently waiting on fedex to un-loose a package with some coolant lines for the heater core.
Air box, ended up using a '90 Integra Si filter. Not the best choice for obsolescence but it fits well. Originally I had made a j-bend looking piece but it didn't fit under the hood so I made a box that lives under the scuttle. There should be room for a wiper assembly... hopefully.
Heater box with mixer. Core is from a early 90's 323, basically the smallest and cheapest I could find that had simple in/out pipes. Fan is a large computer fan. I had put it together in CAD
to test a while back and it seemed just fine. Mixer is setup for full heat or closed and you can see the control lever in the under dash pict.
Under dash shows how much space is lost to the air and heater box and my anti theft / storage shutoff switch.
Under hood organization. Positive leads are made and run where they need to go. Shut off switch is tucked under the coolant bottle and the wiring loom has been cut apart for general lay out and to remove unneeded stuff. Next up is wiring the ignition switch, GM SARVC alternator controller and fuel pump. That's a VW coolant recovery tank from a 2012 GTI. The empty spot is where the Ford Racing fuse box is going to live.
